Broke and still trying
I'm thinking of putting a 454 with richmond 5 speed into a 68 with 307 and 3spd. I've heard the BB sets the engine back and I don't want to go throught the hassle of relocating and modifying the linkage and zbar, etc. Is there anyone that sells a kit or makes the necessary parts to do this combo? Any help is appreciated.
its all about the +6 inches
I doubt there is a kit, but I may be wrong.
They did make big block trucks with 4 speeds, maybe you could locate the parts and do it up like stock? |
Fabricate till you "puke"
"Ditto", I doubt that you will find a kit for hyd clutch.....you can set it up but will be into some fab time.you might look at a hyd throw out bearing setup(not cheap tho!) I have stock linkage on my longhorn(modified), it has rod ends, & the rod has been set up for a straight shot from the peddle to the bell crank. Im am shifting a 6 spd Richmond/with Centerforce clutch,& the setup works very nice. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
