11-24-2015, 07:21 PM | #1 |
radial tires
i just finished converting a old drag truck [72 c10 509 big block] to a street truck front suspension mostly new, 4.5 drop with those skinny Mickey Thompson sportsman bias ply tires on the front.do you guys think the truck would handle better with radial tires on the front? it has the wide hosier radials on the back. thanks,here is a old photo
11-24-2015, 08:07 PM | #2 |
meowMEOWmeowMEOW
Re: radial tires
Bias ply on the rear is liveable since all the low speed vibrations are taken up by the suspension, as is much of the wobble. I personally wouldn't run a bias ply on the front if a radial is available to you. The weight bias on these trucks means those little fronts are doing all of your turning and most of your braking. On the street, the radials offer longevity and control benefits.
My truck is basically the opposite, a street truck slowly working into a drag truck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
11-26-2015, 06:06 PM | #3 |
Re: radial tires
I had a 205 radial in the front and went to a 28x5 bias in the front.I still do some street driving but was never expecting to do much high speed cornering.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
11-27-2015, 05:24 PM | #4 |
Re: radial tires
thanks for the help.
12-07-2015, 10:19 AM | #5 |
Re: radial tires
Vw size radial would be close to what you have in Bias ply tires.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
12-07-2015, 04:20 PM | #6 | |
Re: radial tires
most of the guys who pull dual duty around here have gone that route.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
12-08-2015, 06:43 AM | #7 |
Re: radial tires
great , i never thought of a VW tire i will check into that, thanks
