11-29-2015, 01:58 AM | #1 |
1947 Chevrolet 3100
Hello,
New to this forum.. I recently bought a 1947 1/2 ton 5 window Chevrolet truck. My question is if anyone knows if there is actual difference in overall measurements Length and high of the truck between 1947 1/2 ton and 1947 1/2 ton Thriftmaster ?? or - and what this ,,Thriftmaster'' means ? Thank for all the help! Pete |
11-29-2015, 07:09 AM | #2 |
Re: 1947 Chevrolet 3100
do you have any pics? It is my understanding that those are one and the same thing. I have never seen a 5 window '47, not to say they don't exist, just I have not seen them. My '47 was the base model and it still said thriftmaster on the emblem.
mike |
11-29-2015, 10:01 AM | #3 | |
Here are some picture. |
11-29-2015, 07:53 AM | #4 |
Thriftmaster is the marketing name for the engine. IIRC the 261 available in 2 ton trucks was sold as the Loadmaster.
11-29-2015, 11:23 AM | #5 |
You might have a non-47 cab on there - at the very least those are 52-54 doors because they have the vent windows and push button handles.
Build Thread: "Marvin" (1953 3100) |
11-29-2015, 11:38 AM | #6 |
nice grab.. looks clean... is that already on a s10 frame..
11-29-2015, 12:06 PM | #7 |
12-27-2015, 11:52 AM | #8 |
God please noooooooooo
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
12-27-2015, 12:26 PM | #9 |
12-27-2015, 12:56 PM | #10 |
12-27-2015, 01:20 PM | #11 | |
I just hate to see it because sooooooo often it's done by people who don't know that they could be driving the stock truck or a modified stock frame just fine, they don't need anything more, it's not a big deal to drive the stock truck with the drum brakes and all every day, it's soooooooooo over thought. "Can't drive with drum brakes on the modern highway" I want to SCREAM.....as I drive my stone stock 1959 Rambler every single day. Sorry original poster, back to the cool new truck you bought. Brian
11-29-2015, 11:39 AM | #12 |
Is the gas tank in the cab, or, under the bed?
Steve. 1950 Chevy, 3100, built in Norwood Ohio, USA. My build thread, http://talk.classicparts.com/showthread.php?t=19110 |
11-29-2015, 11:50 AM | #13 |
11-29-2015, 11:53 AM | #14 | |
If i buy regular 47 door windows and trim, would i be able to replace it so it looks like 47 door from the outside? |
11-29-2015, 01:41 PM | #15 |
Hollister Road Co.
The window mechanism and tracks are different, the glass is different the door latching and handle are different. It would be easier to get 47 to 50 doors. Not 51's as they are only for 51.
11-29-2015, 02:48 PM | #16 | |
Also I attached picture of the rear end and suspension. What do u think, Does it looks stock to you? Pete |
11-29-2015, 11:44 AM | #17 |
Hollister Road Co.
You have a 1947 second series 5 window Chevrolet Thriftmaster. It should have a gas fill between the cab and bed on the right side. Thriftmaster was used much like Apache and Silverado are. Your Serial number should start wit EP if its a 47 half ton. The doors as stated are later.
11-29-2015, 11:58 AM | #18 | |
The Chassis number starts with EP....Before that there is a #3 and then it continues with -K Do you know what that means? |
11-29-2015, 01:37 PM | #19 |
Hollister Road Co.
11-29-2015, 05:43 PM | #20 |
Hollister Road Co.
Yes its stock.
12-27-2015, 01:15 PM | #21 |
12-28-2015, 06:24 PM | #22 |
Question for you. This grasshopper looking thing mounted to the frame is what? is it some kind of shock absorber suspension piece and is it original to the frame? looks like directly underneath of it is piece of metal with hole ( maybe that is where is supposed to be mounted?)
12-22-2015, 06:20 PM | #23 |
Hello, Do you know if there was a difference in gauges with red needles or gauges with white needles?
Thanks Pete |
12-22-2015, 08:41 PM | #24 | |
Hollister Road Co.
54 and 55.1 were a different gauge in appearance and mounting. |
12-27-2015, 11:43 AM | #25 |
Does it have a single shackle assembly pivot supporting the rear of the cab? If so it is a '47 cab. That uses two rubber bumper pads out towards the cab corners. That was replaced a few years later with rear shackles at the cab corners.
