Old 12-01-2015, 01:02 PM   #1
LuvNLife
LuvNLife's Avatar
Mystery Motor Noise In Dash Area On Key Off
This is probably normal, but I'd sure like to know what it is.
Whenever I turn off my '87 (no computer, no smog equip, carbed), I hear what sounds like a small electric motor run for several seconds. It sounds like it's coming from under the dash, right in front of me. Also, this is with the HVAC off, blower motor set to off.
Thoughts on what this could be?
LuvNLife is offline   Reply With Quote
Old 12-01-2015, 04:00 PM   #2
rich weyand
rich weyand's Avatar
Re: Mystery Motor Noise In Dash Area On Key Off
You sure there is an "OFF" on that blower motor? Law regarding trucks was that the fan always had to run on at least "LOW" to keep exhaust fumes from getting into the cab. I suspect what you think is OFF is really LOW, and you are hearing the blower winding down.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 12-01-2015, 04:14 PM   #3
LuvNLife
LuvNLife's Avatar
Rich,
I'd thought about that, but I'd swear that the "mystery motor" activates after the key is off. What it sound like, is if there were a motorized door of some sort that opens with key on, then closes with key off, if that make sense. But, I know all of the various vents are vacuum actuated. That said, I never hear it when I start the truck, cold or warm.
Jerry
Old 12-01-2015, 04:39 PM   #4
hatzie
Moderator
hatzie's Avatar
Off is not off.
If you look at the wiring diagrams you'll see blower LOW is turned on with the ignition.
Vacuum bleeding off from the heater control doors?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-01-2015, 04:40 PM   #5
Zach079xxx
Zach079xxx's Avatar
Unplug your blower motor and see if you still hear it.
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 12-01-2015, 05:16 PM   #6
nsulacountry
Blower motor on all squares that I have been in cannot be shut off. Only set to LOW.
Don't know why though.
You have an 87 with a carb?? Must not be stock.
CT
nsulacountry is offline   Reply With Quote
Old 12-01-2015, 07:03 PM   #7
Liberty
Liberty's Avatar
You all say that, but my blower motor in my 82 does not run unless I tell it too by turning on either the AC, VENT, or HEAT.
That being said, it IS possible the P.O modified it, but i still have all my speed settings nor I have noticed any obvious changes to wiring. Judging by the way the aftermarket radio had been installed, I think I would notice.
Liberty is offline   Reply With Quote
Old 12-03-2015, 03:27 PM   #8
jjmorrse
If it sounds like something electrical, it might help to create the situation where you hear the noise, then pull individual fuses to see if one makes it go off. Should be on an always hot circuit, I would think. I think I once heard the lack of an off setting on the blower was a way to keep the hvac from getting dank and moldy, when I was trying to figure what the different settings did to the vac operated flappers.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
