09-17-2003, 11:09 AM | #1 |
What MPG should I be getting?
What MPG should I have 4X4 longbed with 33" tires 4.56 gears w/posi and 700R4?
84 Silverado, |
09-17-2003, 11:31 AM | #2 |
www.73-87chevytrucks.com
If you are lucky, you will break past 10mpg. More realistically expect about 8-10. After some tuning, it might get 12, but that is about the max for a 4x4.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-18-2003, 05:53 PM | #3 |
LED King
what engine? - BTW why do you have different gear ratios from front to back? that is very bad for the 4X4 system.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
09-18-2003, 09:59 PM | #4 |
I have 3.07 in the front
4.56 inthe rear wuz up
84 Silverado, |
09-19-2003, 03:42 AM | #5 | |
Hmmmm May be someone switched one of the axels ?? I always thought they were to be matching ratios, otherwise the odd tire rotation would be hard to control on steering |
09-19-2003, 04:40 AM | #6 |
drove 107 miles and filled up 8gallons. = 13.375 mpg
to bad the speedo is off and not adjusted for my setup so I am probably doing more like 10mpg
84 Silverado, |
09-19-2003, 09:41 AM | #7 | |
09-19-2003, 01:24 PM | #8 |
I had a friend of mine check it out for a few feet,
when I noticed the back tires skipping, I told him to stop and get out of 4X4 mode. sucks that I can't use 4x4, waiting and hopeing the guy that sold me the truck will fix the problem
84 Silverado, |
