12-04-2015, 01:25 PM | #1 |
Rear axle interchange?
Does anyone know if a 1999 suburban rear axle is the same width as my 1985 C/10. I see it has the same 5x5 bolt pattern. I'm looking for a rear axle with 3.73 posi for my LS swap.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
12-04-2015, 01:54 PM | #2 |
Re: Rear axle interchange?
Ive been wondering also---
Im wanting to swap the 3:08 open end gears in a 79 to 3:73 with posi. |
12-04-2015, 08:59 PM | #3 |
12-04-2015, 09:04 PM | #4 | |
I beleive the 1999 burban will be wider than your truck rearend. THe spring pads may also be in a different place which isnt a big deal and the brakes may be different. It will work but there will be some differences to take into account.
Anthony |
12-04-2015, 10:28 PM | #5 |
It's not bolt on, different widths...
BTW GM production "posi's" don't hold up very well. Best bet is to add aftermarket gears and posi unit.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
12-20-2015, 10:39 PM | #6 |
12-04-2015, 11:03 PM | #7 | |
At the body shop.
http://67-72chevytrucks.com/vboard/s...d.php?t=373438
" That didnt make it any newer " " Dont antique the equipment " |
12-05-2015, 10:43 AM | #8 |
I'm going to the junkyard now to measure the suburban' s rear axle.
12-05-2015, 08:37 PM | #9 |
The 1999 suburban rear is 65.5" drum to drum.
My 1985 C/10 rear is 65" drum to drum.
12-05-2015, 08:39 PM | #10 |
So its only .25 wider per side but the spring perches and shock mounts are in different locations. And the oem posi isnt very strong.
Anthony |
12-05-2015, 09:54 PM | #11 |
It might be a bolt-in rear. It has dual spring perches on each side. The inner perches might be for the earlier narrow frame?
For my situation, I'm going to cut off the spring perches anyways as I'm doing an axle flip.
12-05-2015, 10:02 PM | #12 |
My other choice is this 1990 blazer rear. Direct bolt-in, but it is a 6-lug wheel.
I did snag the blazer's cluster I needed for my LS2 swap and the tilt column.
12-05-2015, 09:49 PM | #13 |
good info ya'll
