12-04-2015, 07:29 PM | #1 |
1960 Bottom Radiator Hose Part #?
Ok I have tried two different numbers. First was the one listed for a 1960 with a 283. It fit on the water pump side but on the radiator side it had a bend that when hooked up pinches off the bottom hose.
Next I got a part number from another guy. NAPA crossed that number over. That hose came today it isn't even close....I hate the looks of those universal hoses but Im going to have to use one I guess....HELP... |
12-05-2015, 01:51 AM | #2 |
60-66 Nut
Re: 1960 Bottom Radiator Hose Part #?
Is your small block in it's original location, front to back? Does it have a short water pump as small blocks were originally equipped in all trucks '72 and earlier? Which radiator do you have?
12-05-2015, 07:23 AM | #3 |
Stock position short water pump. Radiator is a aluminum with bottom passenger side outlet..
12-05-2015, 02:32 PM | #4 |
so it's to long? some hoses you have to cut to fit.
1961 chevy K10 my build is------------61K10 build |
12-05-2015, 10:55 PM | #5 |
Nah they were not even close. I went to the NAPA store today. I said turn me loose in the hose rack....I found one that is PERFECT!!!! I just have to cut off one goofy bend....No big deal...
12-06-2015, 12:19 AM | #6 |
60-66 Nut
Do you have a part number you could share with us? Maybe an installed pic too?
12-06-2015, 12:47 AM | #7 |
But Found Her 25yrs Later!
Also interested in which one worked out.
