12-06-2015, 10:13 AM | #1 |
Whining noise?
I have a low speed whine in my 72 2wd I have replaced center support bearing,u joints,pan hard bar and a new rear pinion yoke seems to be getting worse instead of better.
12-06-2015, 10:18 AM | #2 |
Re: Whining noise?
My other question is did all big block trucks come from factory withTH400 trannys in 72?
12-06-2015, 10:21 AM | #3 |
Re: Whining noise?
Have You narrowed down the approximate location of the whine? Couls even be a wheelbearing describing it like that.
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
12-06-2015, 12:03 PM | #4 |
Re: Whining noise?
Does the noise differ when accelerating/decelerating ? Turning corners ?
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
12-06-2015, 12:52 PM | #5 |
Re: Whining noise?
Looks like the group wants you to focus on the wheel bearings or pinion bearings. Since you're replacing driveline parts I'd take a look at those pinion bearings. If the yoke wasn't properly tightened that could cause the problem.
12-06-2015, 03:24 PM | #6 |
Re: Whining noise?
I am thinking differential noise ring and pinion or the carrier/axle bearings? change in the noise on accel/decelerate would to be coming from the rearend.
12-06-2015, 04:26 PM | #7 |
Re: Whining noise?
The ring/pinion, axle bearings and case side bearings are turning 1/4 of the speed of the pinion/ driveshaft. The noise they make when bad is described as a growling noise. Bad pinion bearings make a whining noise
12-06-2015, 04:41 PM | #8 |
Re: Whining noise?
Does this whining sound only occur while your wife is in the truck?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
12-06-2015, 08:01 PM | #9 | |
All about them K’s
Re: Whining noise?
In all seriousness, just kidding. I'd be looking at the pinion bearings/preload as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-06-2015, 05:01 PM | #10 |
Re: Whining noise?
It starts about 15-20 mph and gets worse about 45 and it does get worse when accelerating don't seem to hear it when you get up past 55 or so.I was told I probably screwed things up when I tightened the yoke down.I didn't think I really over tightened it but I guess its possible.
