Old 12-09-2015, 07:00 PM   #1
chris989
power window switch
Hello all,
Anyone know where i can find a power window switch fro a driver front 89 suburban? the 4 switch that controls all the windows. I really only need the bezel as it is cracked and i can only locate an entire switch from LMC trucks.
LMC wants 100$ for it and it probably sucks.
Mine works fine, it just will not stay in the door panel because the tab has cracked off.
Thanks in advance,
Chris
chris989 is offline   Reply With Quote
Old 12-09-2015, 07:08 PM   #2
68c10owner
68c10owner's Avatar
Re: power window switch
I got my ACDELCO switches from rockauto. Mine are only double and single but I'm sure they have what you need.
Anthony
68c10owner is offline   Reply With Quote
Old 12-09-2015, 07:43 PM   #3
wildwilly4x4
I got my master switch on ebay, along with buying new switches for the pass, and back doors for my crew cab. I also did the relay mod at the same time so that my switches and everything would all be new. Switches should last forever after doing the relay mod, and my windows are faster than ever. I think I got all of my switches total in the $75ish range (AC Delco brand)
wildwilly4x4 is offline   Reply With Quote
Old 12-09-2015, 11:32 PM   #4
chris989
Thanks for the replies,,
It is the 4gang switch i I need, really just the chrome trim..
I am doing the relay mods too, WOW what a difference, I can not believe i put it off so long.
I find the 4gang switch but it say 1977-81. I will check ebay again
Old 12-10-2015, 11:15 AM   #5
Man With A Gun
Man With A Gun's Avatar
What is this relay mod?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 12-10-2015, 11:48 AM   #6
gmachinz
There are a few options. The most common is adding relay off the switches to carry the voltage load. Its more efficient than the switch carrying the loads. I take it a step further by adding solid state relay modules to provide relay power AND auto down. I also make them with auto up as well for most years. Relays can be easily added to your existing harness IF they are in good shape-the most common problem is the wire strands coming out of the OEM switch cavities break apart over time. I've solved this design flaw in my harness constructions but if you use your existing harness just be sure to carefully inspect it all before adding any kind of mod such as a relay upgrade.
gmachinz is offline   Reply With Quote
Old 12-10-2015, 01:30 PM   #7
68c10owner
68c10owner's Avatar
I have new ACDelco switches that I haven't installed yet. Could I use them for your auto up/down mod?
Anthony
Old 12-09-2015, 11:34 PM   #8
chris989
I checked rock auto,, they only have the single and double.
chris
Old 12-10-2015, 10:48 AM   #9
gmachinz
I have a few nice switches w/nice bezel....$35 shipped to your door! PM me if interested! The 77-81 are stainless I believe while the later ones are plastic...and, the window motors are different for those years as well.
