Question regarding AC/Heater removal
I've found a thread or two regarding this question, but my setup is a bit different so I wanted to be sure before changing anything.
For removing (deleting) the entire AC/Heater assembly, can I plug both outlets (with a brass plug) at each arrow location in the photo? Thank you! |
Re: Question regarding AC/Heater removal
Not until you replace some of that rubber fuel hose with steel! Grab a trans line from Schucks or something! Or better yet, any small block fuel line to get it close enough to the carb that you don't have so much rubber, particularly by the exhaust.
On the heater I'd say yes, with the only caveat being I've never had a vehicle with the setup that returned the heater flow to the rad instead of the water pump. Unless that serves some special purpose, and I can't imagine what, I'd think it's fine.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
yes you can plug the heater hose outlets with a pipe plug
you could plug the lines, but it will let more coolant circulate, if you just connect the two points, along with the lines, there is no upper water pump line, do you have any overheating issues?
I second getting rid of the rubber fuel lines and replacing them with steel, the rubber lines like to leak, and then start fires. Where you have to have rubber lines, make sure you use fuel injection line, that is specifically make to hold to the chemicals in Fuel. |
#5 | |
Yes, I'll definitely update all the hoses. We don't want any fires!
1972 C/20 LWB, 350/350 |
personally i would connect the two so coolant will still circulate, but if you want things out of the way, then just cap them
When every thing was stock and hooked up, when you turn on the AC it stops the circulation of water through the heater core so since you are abandoning everything just pull the nipples and put plugs in.
69 Chevy 4x4 383 Power ![]() |
#8 | |
Tags |
ac removal, blower, delete, heater |
