12-11-2015, 12:46 AM | #1 |
heater box question
Sorry if this is a dumb question, but I needed to find pretty much every part for the heater in my 69 C10. They truck was an AC truck, but I don't have any of the parts ( switch panel, heater box, heater core, blower ). I was wondering if there are other years, even later square body heater boxes and parts that would fit a 69 just incase I'm at a junk yard and see some parts. Thanks for all the help!
12-11-2015, 12:52 AM | #2 |
Re: heater box question
Are you looking for A.C. or NON A.C. parts? I have a complete NON A.C. system that would work in your truck.
Let me know if interested. Thanks, Mike.
1971 Cheyenne Super C-20 402 4 speed 1970 El Camino L-48 350 1999 Chevy Z-71 Extended Cab 4x4 2000 Tahoe Z-71 2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator 1970 Chevelle, Malibu Sport Coupe 2007 Harley-Davidson FLHX Street Glide |
12-11-2015, 01:38 AM | #3 |
AC or non AC, I'd be into either! I really just wanted to slowly start getting the parts sourced and put together so I can get a little heat going in the cab, haha and mainly defrost in the early morning commutes to work. I'd be into anything you'd have! Thanks for the responses everyone!
12-11-2015, 12:59 AM | #4 |
Hey dude, I'm not sure if the square body parts are similar. From the looks of the LMC Catalog it shows most of the HVAC parts are similar from 67-72.
So it's safe to say they should all fit in the cab. Now there may be some differences in the compressor, AC lines, etc. As far as the components in the cab should all be the same. Can someone correct me if I'm wrong. I'd offer you my heater box etc, but I have a non AC cab and I belive the air box is different. Hope this helps some. Dave |
12-11-2015, 01:29 PM | #5 |
If you have a factory ac truck then you really want to stick with heater box that goes with that style especially if you have the ac box under the hood. The non ac trucks use a -different setup. and only. And only 67-72 will bolt in
12-11-2015, 01:32 PM | #6 |
here is the heater box that goes with a factory ac setup which goes under the dash
12-11-2015, 01:43 PM | #7 |
And the heater box for a non ac truck that bolts on in the engine compartment.
12-12-2015, 12:24 AM | #8 | |
The Older Generation
The firewall is also different between the A/C and Non-A/C trucks so they are not directly interchangeable.... LockDoc
12-12-2015, 01:15 AM | #9 |
Here's a nice one with a good heater core, I removed from my 72 to install a vintage air system.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
