12-20-2015, 12:27 AM | #1 |
Brake booster question
I need to put a smaller booster in my 72 for clearance reasons. The booster that I am going to use, there is only a threaded rod. My question is, what are you guys using to connect it to the brackets on the firewall? Any help will be greatly appreciated, pictures will also help.
12-20-2015, 10:14 AM | #2 |
Re: Brake booster question
You can fab brackets and connectors or whatever it takes, but $200 and a couple of minutes on eBay will get one delivered to you that has correct brackets, connection to the pedal, master cylinder and proportioning valve.
12-20-2015, 10:33 AM | #3 |
Have you looked to see if the clevis on the OE stuff is threaded to use on there? It should be.
12-20-2015, 11:55 AM | #4 |
12-20-2015, 11:33 AM | #5 | |
70+ ( Old Skool Club )
http://www.ebay.com/itm/331727866741...%3AMEBIDX%3AIT
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-20-2015, 11:49 AM | #6 | |
12-20-2015, 09:20 PM | #7 | |
12-20-2015, 11:31 PM | #8 |
Thanks for your help but I do not need the whole unit I only need the clevis that screws on the end of the threaded rod coming out of the back of the booster. Can anyone help me find one or direct me on where to go looking.
12-20-2015, 01:03 PM | #9 |
You might try http://vintagechevytrucks.com/ . They are like a wrecking yard for these trucks. I bought a complete OEM setup from them to convert mine to power brakes.
There web site is still screwy but the contact information is there.
Terry Soon to be retired and moving to Bristol, TN. |
12-21-2015, 01:54 AM | #10 |
I cut the end off the stock one and welded it to the rod on the new smaller booster I used. Worked like a charm.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
12-21-2015, 11:03 AM | #11 |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
