12-21-2015, 02:58 PM | #1 |
Saddle tanks on a Task Force?
After much searching I haven't been able to figure out if anyone has ever tried and/or succeeded in mounting saddle tank(s) on a '58 or '59 Task Force Fleetside. I understand a rear mounted tank is popular, but I'd like to consider saddle tank(s) to avoid having a bed style filler.
I am also wondering anyone has fabricated a "behind the tail light" filler on a 58 or 59 Fleetside? The tail lights are certainly large enough to hide it for sure. The main reason for removing it from the cab is to make enough room for an overnight bag or two. With the tank in the cab, there's no chance of that!
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
12-21-2015, 06:55 PM | #2 |
Re: Saddle tanks on a Task Force?
suburban/panel truck tank would work, but no one repops them and they are rare as hen's teeth
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-21-2015, 09:11 PM | #3 |
inlet pipe does not have much slope, but you can do a side mount.
12-21-2015, 09:30 PM | #4 | |
The side spears thwart the height. (New word I'm trying out). I don't mind the side fill at all except I'm concerned about the height so was thinking hinged hidden tail light access. Would the tank from this donor work?
12-23-2015, 12:14 PM | #5 | |
you could also use the stock fill location and pipe to the tank assuming you could mount the tank on the drivers side if you look inside that panel it does have a hump around the filler neck inside the bed
12-23-2015, 01:13 PM | #6 |
Probably but look where the fill door is, right in the middle of where a FS bed spear is. I also considered putting the fill in the top of the bed rail or on the side above the spear, dropping down and across to the tank.
12-21-2015, 09:55 PM | #7 |
behind license plate.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
12-21-2015, 10:04 PM | #8 |
That could work too but what about the height of the filler neck...is it high enough? I'm assuming it is but have to ask. What kind of tank did you use?
12-21-2015, 10:26 PM | #9 | |
the filler neck is high enough...not ideal..i have to be careful and not fill at full speed. i keep a shop towel handy just in case, and i fill up with no problem
12-21-2015, 10:35 PM | #10 |
I think If I was to run the rear fill under the back of the bed I'd want to run a non vented cap and then run a vent hose with a little filter on it up in one of the stake pockets to get it up several inches above the top of the tank. That way you should be able to get away from the gas slosh problem on acceleration that we often had with tanks that filled behind the license plate in the late 50s and early 60s.
12-21-2015, 10:43 PM | #11 | |
My 1969 Oldsmobile 442 had a behind the plate tank filler! Talk about acceleration!
12-21-2015, 11:27 PM | #12 |
I had a rear tank on my '64 fleetside with the filler behind the tail light. It sucked. On mine, the light just had two thumb screws that you unscrewed and pulled the light assembly out. That was OK but, even though the filler is mounted high, the neck still had to level out under the box to get to the tank and was a pig to fill. It took FOREVER to dribble the fuel in. Took the whole thing out and put the tank back behind the seat like the general intended. Personally, I LIKE the way these trucks were designed asthetically from the general and, if I needed that space behind the seat, I would have a custom aluminum tank made that went ahead of the diff and stradled the drive shaft (kinda like joined saddle tanks) and fabricate a filler neck that used the factory cap location and went through the floor behind the seat to the tanks.
12-23-2015, 11:07 AM | #13 | |
I appreciate all the replies! I started looking at different gas tanks and found some interesting options? including motorcycle tanks and 4wdr tanks for the RZR etc that may be able to be fabricated to make work by using two of them. The search continues!
12-21-2015, 11:27 PM | #14 |
my tank came with a vent hose next to the feed hose
12-23-2015, 12:09 PM | #15 |
Frank,
How did you/where did you terminate the vent hose? I guess I've never really thought of venting before but makes sense that I'll have to have one. The suggestion to terminate it in one of the stake pockets seems good but I'd have to put something on the end to keep miscellaneous "stuff" from falling into it, I guess. Also, is that a standard elbow provided by Tanks, Inc? No issue with the gas eating the rubber hose so far?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
12-23-2015, 01:30 PM | #16 | |
12-23-2015, 09:44 PM | #17 | |
I will take a look at how the vent hose is terminated tomorrow ( my mechanic installed the tank for me )
12-22-2015, 06:49 AM | #18 |
what's that black cylinder thing on the rear of the frame rail?
clean setup there. |
12-22-2015, 08:09 AM | #19 |
oh thats just a piece of rubber hose that came with the kit laying there
12-24-2015, 02:07 AM | #20 |
Thanks, Frank!
