'63 c10 drag build
making some good progress looking for any pointers
Registered Truck Offender
Re: '63 c10 drag build
Probably will anyways,,, but, just be aware because you have altered the firewall, you will need a full SFI certified cage, SFI window net, SFI firesuit, clutch / flexplate / bellhousing shield, Trans shield / blanket (or SFI case trans),, Might as well make it light enough to run 8.50,, your going to have to have all the safety equipment to be there anyways.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
Thanks man yeah I picked up the rule book I've been having trouble understanding the language of it. Like where certain bars need to be for an altered firewall.
I dont think those headers are allowed in that class either.... may as well get rid of them - - - - want to sell them???
My Build: 57 Chevy Pro-Street |
$750 @ mad dog headers
Yea I checked them out --- very nice!
Your build is looking good, is it going to be track ready this year you think? I suspect you will be coming to SAC raceway or is there a place up in Chico area to run?
yeah ill make it to sac there is actually a drag strip in redding the oldest nhra track in the world you should check it out there is a race the farmtruck will be at on feb 13 starting in the mornign with autographs his truck is being built up there by a guy
heres how far ive got and some info on the farmtruck
What back half is that?
Any way you can post a picture of where it is tied into your frame? |
Yeah sure
Posted via Mobile Device |
Here it is
Will be cool to see a few other trucks in my area able keep up with me if not get around me
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Did you weld that on?
Reason I'm asking I posted a thread about a weld in back half. Going to go 4 link with narrowed 9" Did you box where the back half is located and welded it to the box portion? Also what size tire and backspacing are you going with ? I'm looking at running some 15x14 prostars but no idea what BS I want to run |
#15 |
Yeah welded in its a back half for a camaro so the frame sizes are different so it's boxed and coped around the back half.
Weld 15x14 3.5" bs The axle housing end to end is 34" |
#16 |
I was thinking a 7.5" B.s. for mine to keep strain off the rear end. Do you think that will be ok to run?
I finally found a decent video of a backhalf install on a s10 yesterday. I may just take mine somewhere and have it installed. I was going to box the stock frame behind the cab then see what we can do as far as welding it in. What's your thoughts on this? |
#17 |
I ran a 12" wide wheel with 7.5" back space for years. I only recently went to a 12" with 4.5" bs when we built this rear. Ironically when I decided to go to the 32x14 my old 12" / 7.5 bs put the bigger tire exactly where it needed to be. Only thing is I wish it were a 14" wheel.
#18 | |
I am trying to find a cheap match for discs..
my build http://67-72chevytrucks.com/vboard/s...d.php?t=210902 |
#19 |
Ah ok. See I didn't know if 7.5 would be ok.
My 15x10 prostars had a 4.5" bs. And with 325/60/15 drag radials I ended up rolling my fenders but had no issues other than that. I couldn't go wider because of my leaf springs and stock wheel tubs. |
#20 |
When I had the stock rearend I ran 32x14.5 with some steel rims I made my own backspace took the inner fender out they fit rims were 15x15
#21 |
Here they were still have the rims
#22 |
sorry pic didnt load
#23 |
as far as the back half you should check out the chris alston intructions its written but good
#24 |
#25 |
Thanks for the pics. Looks badass! I think I'm going to start a thread on welded back half and get some ideas. If we can do it at my friends shop I would rather do it their than a chassis shop 3 hours upstate Ms
