12-27-2015, 05:22 PM | #1 |
Battery Disconnect
Would it pass tech inspection if I mounted my battery disconnect on the side of my truck like this? It has the on off decal I just mocked this up for reference of where I'm talking about. What do yall think?
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
12-27-2015, 06:13 PM | #2 |
Re: Battery Disconnect
Pretty sure the rule state has to be on the rear of the vehicle, don't have my book handy at the moment..
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
12-27-2015, 06:15 PM | #3 |
8:4 MASTER CUTOFF
Mandatory when battery is relocated, or as outlined in Class Requirements. An electrical power cutoff switch (one only) must be installed on the rearmost part of each vehicle and be easily accessible from outside the car body. This cutoff switch must be connected to the positive side of the electrical system and must stop all electrical functions including magneto ignition. The off position must be clearly indicated with the word “OFF.” If switch is “push/pull” type, “push” must be the action for shutting off the electrical system, “pull” to turn it on. Any rods or cables used to activate the switch must be minimum 1/8-inch diameter. Plastic or keyed switches prohibited. Switches and/or controls must be located behind rear wheels on rear-engine dragsters. Technically its part of the rear most part. lol
12-27-2015, 07:32 PM | #4 |
Registered Truck Offender
I'm sure tech will argue that one, Rear-most means BACK,, unless it's a dragster which really has no 'width ' at the back.
Also, that looks like a decent one, but I can't ID it. Many of the cheep rotary disconnects are only rated for 20-40 continuous amps. (a complete JOKE!)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-27-2015, 07:42 PM | #5 | |
12-28-2015, 08:23 AM | #6 |
If your doing dual batteries,,,, might consider isolating each and not running both through one switch. Bickel is quite proud of everything they sell,, but honestly quality is next to none.
This kit has dual 125 continuous switches, but for another $40 or so you can get dual 300 amp switches. http://www.jerrybickel.com/batteries...-jbrc1026.html
12-28-2015, 06:24 PM | #7 | |
It's Better With Nitro
...note the activation lever protrudes to the outside of the trunk. You will also need to have a notation (sticker, lettering, etc.) that indicates which direction the switch shuts off the electrical system. If it is a push/pull activation, push has to be the OFF.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-28-2015, 07:05 PM | #8 |
Yeah baby!
I mounted mine in the license plate area of the rear bumper.
11.37 @116 |
12-29-2015, 10:24 PM | #9 |
01-02-2016, 05:31 PM | #10 |
01-07-2016, 12:03 AM | #11 |
I dont have a bumper to run mine through but I have a plan. Stay Tuned...
01-07-2016, 10:02 AM | #12 |
Mine run through my rear roll pan with a remote switch.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-07-2016, 10:47 AM | #13 |
mini truck racer
Take the 2 bolts for the tail light mount and build a bracket that bolts on right there . wires will still be close to the same spot , body wont be modified , and it is visible and accessible from the rear .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
01-07-2016, 11:07 PM | #14 |
Well this was my solution. Still need to mount it better but license plate will go in the middle. Ill have to add bolts on the outer edges for stability.
01-08-2016, 09:35 PM | #15 |
Well here's the finished product. Kinda hoaky but it works. Now to just to wire it all up..
01-09-2016, 11:11 PM | #16 |
Nice! Be sure there is support at the rear of the panel to keep it from flexing out since there is a significant high pressure area at the point just behind the panel when the truck is at speed.
01-09-2016, 11:21 PM | #17 |
The place it's bolted to is actually the last bed brace which is a c channel type brace so it won't flex. I bolted it through both sides as well. The aluminum is also thick so it wont flex either.
01-19-2016, 03:30 PM | #18 |
This is a very simple and economical way to do it. It will mount just about anyplace with just a 1/2" drilled hole. Bumper, rear fender, rollpan....
125A Switch (carrys most any street vehicle) for $35 http://www.jerrybickel.com/batteries...-jbrc5513.html
My Build: 57 Chevy Pro-Street |
01-19-2016, 04:00 PM | #19 |
Its all finished up now. Rewired the whole truck front to back.. here is a shot of the finished product on the back.
01-19-2016, 04:04 PM | #20 |
That looks awesome! -- nice rig!
