12-30-2015, 02:34 PM | #1 |
Seat belt help please
Need location to find the hole for 3 point seat belt...PO filled them in. I would like to use original location. Thanks
12-30-2015, 05:20 PM | #2 |
Re: Seat belt help please
I think you're going to need to make a tracing from another truck, unless you can locate the spot with a magnet.
See if you can find the center of a spot where a magnet doesn't stick (or stick as well). Maybe the filled it with body filler and you can just dig it out with an awl and then a thread cleaner (do NOT retap the hole).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-30-2015, 09:59 PM | #3 |
I can take some measurements if needed. Send a PM, and another if you figure it out before I get back to you.
Snapping a few hirez pics is easy tomorrow. Getting, or rather thinking, and getting real duplicatable measurements may be tomorrow afternoon You may be able to find locally a cheap paint thickness gauge (like dave said) (little spring and magnet thing) to zero in once you get close if you like the paint. The trouble I see is I have rubber and glass so there are no good X, Y and Z reference points to measure from. If you have an assembled truck, this may work ok using say, a straightedge on the lower rear window rubber... |
12-31-2015, 01:38 PM | #4 |
Thanks for the help!!
