Old 01-03-2016, 11:48 AM   #1
farmallboy15
Brakes, nothing until bottom, then lock
I'm currently looking at buying an 85 k3500 dump truck. I took it on a short test drive and thought i was going to die...
Hydroboost system:
When you press in the brake pedal, nothing happens until the very bottom of the travel. At that point, the rear brakes lock up. Nothing from the front by the feel of it. The top travel where it flops around, you get some random back pressure, feels like the booster. The idiot light is not on.
My thoughts: large air bubble in the lines, proportioning valve needs reentered and rebled. Or a bad master cylinder.
Any and all ideas are appreciated!
70 GMC K2500
82 GMC K3500
09 GMC 2500HD 4x4
farmallboy15 is offline   Reply With Quote
Old 01-03-2016, 12:13 PM   #2
BugzC10
BugzC10's Avatar
Re: Brakes, nothing until bottom, then lock
Check the power steering fluid level or loose belt.....the hydroboost uses the power steering pump.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-03-2016, 12:27 PM   #3
farmallboy15
The PS fluid was low. But the lack of the booster should just make the pedal harder to push, not make it spongy... Right?
70 GMC K2500
82 GMC K3500
09 GMC 2500HD 4x4
Old 01-03-2016, 12:37 PM   #4
BugzC10
BugzC10's Avatar
I believe you are correct. As you stated, at least try bleeding the brake system to see if the MC is pushing fluid.
