Old 01-05-2016, 08:50 AM   #1
jmader
jmader's Avatar
Quick and Easy Fix for Exterior Door Handles
I'm restoring a 1967 GMC and decided to have my exterior door handles re chromed. The problem with these door handles is that it's impossible to disassemble them without breaking the tabs that hold the plunger in place. I came up with a cheap solution that j wanted to share because these break a lot also and this is a cheap alternative to buying new handles. I picked up a piece of 1 inch aluminum tubing from Menards for a few dollars.
I cut a 1 1/4 inch chunk off of it then cut that piece down the middle.
Then I drilled a hole for the plunger and fit the piece inside the door handle. The opening is tapered a little bit so you have to grind one end to get it to fit properly. I put the plunger back in the door handle followed by the spring then used some aluminum rivets to hold the whole thing in place.
There you have it. Just a few dollars and about 15 minutes and your door handle is better than new.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 01-05-2016, 08:58 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Quick and Easy Fix for Exterior Door Handles
That's pretty slick. Thanks for sharing the idea.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-05-2016, 09:01 AM   #3
midniteblues
midniteblues's Avatar
Nice job its well done an should last.
I could've used this fix 2 months ago on a 71. Instead I used a 67 handle on it. Witch is something I didn't wanna do.
Its these kinda threads that makes this board so great.
Thanks for sharing
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-05-2016, 09:26 AM   #4
tk1251k
tk1251k's Avatar
Nice innovation and great pics.Thnaks
tk1251k is offline   Reply With Quote
Old 01-05-2016, 12:31 PM   #5
Hart_Rod
Hart_Rod's Avatar
Nice job!
Hart_Rod is offline   Reply With Quote
Old 01-05-2016, 01:18 PM   #6
Boog
laying low
Boog's Avatar
That's good thinking and looks like it will hold up for a long time too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-05-2016, 01:43 PM   #7
kehstr
kehstr's Avatar
The best thing about the way the door handles work on these trucks, is if it does happen to brake, you can still open the door without the button, I've done it a few times, just being to lazy to change the handle.
kehstr is offline   Reply With Quote
Old 07-21-2016, 08:45 AM   #8
skarweb
Thanks for this solution. Another quick solution (when still having the square plates) can be done by two electric wires (cupper 2.5mm).
skarweb is offline   Reply With Quote
Old 07-21-2016, 09:44 AM   #9
n33k0
I'm gonna try this, the plunger on my passenger door fell apart recently. Thanks for the info!
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 08-12-2017, 06:08 PM   #10
huntznsam
Thank you! The PS handle on our 72 popped apart this week. Using your idea, we just bent up a piece of 14ga steel since that's what we had, and use #8 flat head sheet metal screws, countersinking the handle. Installed no problem, works great.
Appreciate the great advice,
HuntzNSam
huntznsam is offline   Reply With Quote
Old 08-12-2017, 07:46 PM   #11
bill3rail
bill3rail's Avatar
Hope to never need this, but if I do...
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-12-2017, 07:57 PM   #12
Fbks_Cruiser
Fbks_Cruiser's Avatar
Excellent Idea. I have a couple broken handles I've been thinking of rebuilding and was thinking of bending something up and doing something similar. I like just cutting some square tubing better.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 08-12-2017, 08:39 PM   #13
Orange67
Orange67's Avatar
Awesome innovation. Thank you!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 12-01-2018, 06:10 PM   #14
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Can the rivets be substituted with self-tapping screws?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 12-01-2018, 09:42 PM   #15
notsolo
notsolo's Avatar
I think that would work, but....clearance in the handle opening may be a problem getting the handle back thru sheet metal.
notsolo is offline   Reply With Quote
Old 12-01-2018, 10:39 PM   #16
hugger6933
I have two handles in service right now with the wire like in the above post and it works fine.
hugger6933 is offline   Reply With Quote
