Old 01-07-2016, 04:01 PM   #1
NoNeck
NoNeck's Avatar
Question On Notches for Bed Wood
OK guys, I need the measurements for the notches that are cut into the two short boards that fit into the bedside corners (fleet side).
Or, are these cut-to-fit for each bed?
Thanks, POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 01-07-2016, 07:20 PM   #2
Baddflash
Re: Question On Notches for Bed Wood
I would cut to fit, I cut enough out the boards to clear the tires, installed & marked ,then cut. Why screw it up by using someone else's specs? I would also leave the center two boards till the rest are installed in case you need to adjust their width.
lol didn't look at pic.
Those I measured to fit but removed as little material as possible on the first cut and installed and adjusted as necessary by removing a little each time.
Baddflash is offline   Reply With Quote
Old 01-07-2016, 07:25 PM   #3
Baddflash
If memory serves it was approximately 2" square.
