01-12-2016, 12:27 AM | #1 |
Looking to put 31x18.5x15 tires on my 86 swb
Any pics of how you guys put 31x18.5x15 tires under a 73/87 short bed? Looking for frame mod pics or any inut on this modification?
Thanks, Wes |
01-12-2016, 09:55 AM | #2 |
Re: Looking to put 31x18.5x15 tires on my 86 swb
Dang, why so short and wide? I would like to see that size on a truck for the heck of it but I can't see it being a good mud/sand tire. I'm curious.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-12-2016, 12:01 PM | #3 |
It's a pro street or hot rod tire size. Not off road.
Anthony |
01-12-2016, 10:24 AM | #4 |
I wonder if those are the widest DOTs available... what engine/tranny/axle? What's the measurement from frame to edge of bed? Will you be tubbing it?
1973 C20, 350/350 |
01-12-2016, 11:58 AM | #5 |
2wd. 24" from frame to bedside. I have room for a 4 link outside the frame but have thought about inside the frame. I will use coil overs off the rear of the axle. 4.11 gears with 31's will be like a 3.73 down the highway. not looking for a superfast truck so Im leaving the stock rearend but new posi and axles.
01-12-2016, 12:05 PM | #6 | |
Anthony |
01-12-2016, 03:11 PM | #7 | |
1973 C20, 350/350 |
01-12-2016, 03:34 PM | #8 |
I read it as 4.10 /31 tires and 55mph = 2510 rpm. Im only 17 miles from work.
01-12-2016, 07:14 PM | #9 |
Plus whatever torque converter slip happens if you don't have lockup. It isn't outrageous, but I wouldn't want to drive it a few hundred miles in a day.
1973 C20, 350/350 |
01-12-2016, 12:29 PM | #10 | |
I'm just glad to be here!
Hoosier Pro Street Radial: 33x21.5R-15LT has a section with of 21.3" and a tread with of 16.8" Those are the widest DOT tires available to my knowledge...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-12-2016, 01:48 PM | #11 |
I do not want to narrow the axle. I measured the back spacing and a 15x15 rim with 10.5 of backspace will make it work. I also want to use truck rally wheel centers and have them welded in the 15 inch wide wheels to keep the center caps and rings.
01-12-2016, 04:06 PM | #12 |
I know the pieces fit
That sounds awesome, I want to see this.
01-12-2016, 09:05 PM | #13 |
Just going to cruze around and look cool. Big burnout once in awhile.
01-13-2016, 01:10 PM | #14 |
I did it with stock suspesion.
John 82 Chevy Silverado 350ci/TH350 |
01-13-2016, 01:45 PM | #15 |
Any pictures of the leaf spring mounting points and what size tires, rims and do you remember what the back spacing is?
01-13-2016, 02:07 PM | #16 |
Nice job J. Knight, springs inboard are a nice fab.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-13-2016, 02:36 PM | #17 |
I can't tell in the pics, did you box the frame where you inboarded everything?
Do you have a swaybar? I'd expect the closer spaced leaf springs would allow more body roll. Not sure how much it matters.
1973 C20, 350/350 |
01-13-2016, 05:26 PM | #18 | |
Thanks, it was easier AND harder that I thought it would be. No I didn't box anything, I didn't feel it was needed. I do have a sway bar yet but the slight sway is barely noticeable imo.
01-13-2016, 05:40 PM | #19 |
01-13-2016, 05:51 PM | #20 |
Sweet. I see a 9" peeking back. Did you narrow it or buy it built?
01-13-2016, 06:04 PM | #21 |
I found an old 9in and took it to a local rear end shop by my house and had it narrowed and completely rebuilt.
01-13-2016, 06:06 PM | #22 |
I've always liked your rig J
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
01-13-2016, 06:11 PM | #23 |
01-13-2016, 06:56 PM | #24 |
Did they put custom axles in, or shorten the stock ones and redrill the flanges for the GM 5 on 5 pattern?
