01-12-2016, 12:37 AM | #1 |
best year nonvortec 350?
65 SB stepside
Nonsyncro muncie(will change to synchronized) 3.73 rear Would like a283-327 but seems 350 may be easier/cheaper to find Is there a"best" year to get said 350? |
01-12-2016, 01:53 AM | #2 |
60-66 Nut
Re: best year nonvortec 350?
Are you looking for an engine to build or just a used engine to install and drive? What don't you like about the Vortec 350?
01-12-2016, 02:01 AM | #3 |
Yes just one to buy in or out of a truck
Do minor rebuild and install Nothing about vortex but seems more complicated fuel and some say they prefer tbi to vortec I want just a baseline motor that I can upgrade as wanted and F.I. Isn't what I want to deal with just yet..(very familiar w/VW-Porsche F.I.) Simple carb simple exhaust no extra nothing |
01-12-2016, 09:08 AM | #4 | |
01-13-2016, 01:38 AM | #5 |
60-66 Nut
I see no reason to not use a '96-'02 L31 Vortec engine. You get a one piece rear main seal, the factory roller cam and a set of the best production heads GM produced for a small block. Just drop a carb and intake on it with a regular HEI and you'll have a great engine. You'll need to be sure to change the distributor gear to one that is compatible with the factory roller cam. The only drawback I can see to building a L31 Vortec, is that you'll have to run an electric fuel pump. But that really isn't a big deal breaker IMO.
01-13-2016, 11:28 AM | #6 |
Captain, Will the Vortec intake take a Quadrajet, or is there an adaptor needed?
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
01-13-2016, 11:51 AM | #7 |
01-12-2016, 07:22 AM | #8 |
Well any of the roller cam one piece rear main engines would be my pick. The first vortec engines were the 95 to 2000 small blocks with the vortec heads. That is what is in my truck. These are non LS engines and make good reliable engines. The intake is specific to the heads but still easy to get.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-12-2016, 09:05 AM | #9 | |
01-12-2016, 08:52 AM | #10 |
The Vortec L31 engine is still a Gen1 SBC.You can run a carb on it,or,EFI.It does need a Vortec specific intake.It's a really good engine.1 piece rear seal,roller cam/lifter setup.These motors are rated at 255 HP,but,that is the net rating as installed in a factory vehicle with factory exhaust,tuning,etc.With a good intake,4 bbl carb,& decent exhaust,these engines will hit 300 HP without breaking a sweat with the stock longblock.Add a small performance cam & 350 HP is a cinch.
You will need a flywheel for an 87 up 1 piece rear seal motor.You will also need to use an electric fuel pump because there are no provisions for a mechanical. My 97 has 610,000 miles on it.The original motor was pulled at 248,000 mostly due to low idle oil psi.Motor was still in good shape.When torn down,there was still visible crosshatch & no ring ridge at all.It's in the process of being rebuilt now.I replaced it with a Goodwrench crate L31.(Which,by the way,you can buy a brand new L31 for less than $2000.New complete long block with oil pan,timing cover,& valve covers,not rebuilt.)That motor now has over 360,000 miles on it & still going strong.The EFI & 4 speed auto are a big contributer to that as well. Last edited by jokerz71; 01-12-2016 at 09:03 AM. |
01-13-2016, 02:18 PM | #11 |
though the best 350 came out of a 67 corvette or camaro.. based on power that is..
01-13-2016, 02:33 PM | #12 | |
The 96/2000 350 Vortec has a net HP rating of 255 HP as installed in an OEM vehicle with stock factory exhaust,emmissions equip,& factory pcm tuning.You can take that same motor & put a 4 bbl carb/intake & headers & make an easy 300 HP.The heads on this motor offer an automatic 30HP,just by bolting them on to a motor without any other changes & that's comparing them to something like Humps.Compare them to a smog head & it's more like 40 to 50 HP. That's not mentioning the benefits of the 1 piece rear seal & roller cam/lifter setup. |
01-13-2016, 02:37 PM | #13 |
01-13-2016, 02:41 PM | #14 | |
*** That's interesting ***
Short water pump bolts right up. Can't think of anything besides the flywheel, distributor, and fuel pump that would need changed either. Electric fuel pump is easy and safe if you run it through an oil pressure switch. So my vote is also L31. With carb intake and HEI (if you want old school). By a large margin.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-13-2016, 03:09 PM | #15 |
...not to mention adding a retro-fit roller cam to a non-roller small block is a $900-1000 upgrade. That's half the cost of an L31.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
01-13-2016, 03:16 PM | #16 | |
Every once in a while someone mentions the need for a coolant bypass with the vortec. Is it not cast into the block like all the other SBC's?
01-13-2016, 03:56 PM | #17 |
An old style cover will work,but,requires that you silicone a couple of places as the new cover uses 2 less bolts.The block does not have the bypass cast in.The hole is there in some blocks,but,it is not open thru.Plumbing an external bypass is no big deal.
01-13-2016, 04:33 PM | #18 |
I went through this when I rebuilt my 350. I bought up into the hype and rebuilt a Vortec 350. Great engine but I can't stand the electric fuel pump. It's expensive, loud, needs a regulator and is a pain in the ass to set up. They also require a more expensive intake. For those reasons if I could due again I would try to find a TBI block 87-95? set up for a roller cam and mechanical fuel pump.
01-13-2016, 04:41 PM | #19 | |
01-13-2016, 04:49 PM | #20 |
I am using a blue holly fuel pump, maybe I'll sell it and try that pump. Yes they are rare but they are out there. I searched the junkyards for a month and found a TBI 4 bolt main with the fuel hole drilled. I pulled it but couldn't use it because the block was cracked so I went with a vortec instead.
01-13-2016, 04:53 PM | #21 |
What kind of fuel pressure are we talking?
Stock AirCooled F.I. Pump is about 60psi regulated down to 28-32 Carb elec fuel pumps range 2-4 and 5-7. Dual 44 Webbers take about that and that's a good bit of carburation |
01-13-2016, 10:52 PM | #22 | |
As for the coolant bypass, this has been discussed to death. I am using a Weiand aluminum intake. I just used my heater hoses in stock setup for a 67-72 non-AC truck... one from the intake manifold to the core, the other from the core straight to the water pump nipple. There isn't supposed to be a flow control valve on the old trucks (stock setup uses an air diverter). So it works perfectly as a bypass. No need for anything else. If you have a newer truck or car that needs a coolant valve at the core, just get a 3-way bypass type. Problem solved.
01-14-2016, 10:54 AM | #23 |
Some blocks are not completely finished through to the deck.The hole is present at the front of the block,but,does not go all the way thru to the deck.This would be in the #880 block,96/up.The #638 blocks should all be completely through as the TBI heads were drilled. Some early #880 blocks were indeed open throughout & were machined for a mechanical fuel pump.Generally,if the block has a blockoff plate at the fuel pump opening,it is machined.If not,it's not machined.
01-18-2016, 03:10 PM | #24 |
Come to find out there is an engine in the yard that is a vortec and 4l60e trans
Aluminum heads iron block.. 4.8? 5.3? Heads are 706-99+ Chevy.. Believe it cable out of a 2000 or so? Trying to nail down what year! I'm looking for 96-02 350.. Want to brake to put carb on out for now Will it fit with my 3 speed? What year can I Not just put carb and hei on?? |
01-18-2016, 07:25 PM | #25 |
That is an LS motor.You can put a carb on it, but, there is no distributor. You would have to use an aftermarket controller to run the CNP ignition.Spacing is also different between torque convertor to flywheel.
The L31 Vortec/350 was only available in trucks from 96/99 & in vans & some SUVs until 2001.If your goal is to use a carb & hei distributor, that would be the best option. |
