Old 09-20-2003, 03:36 PM   #1
BookMan
driveshaft repair
I just fixed my broken driveshaft in an interesting way that I thought some of you fellow hillbilly-ers might appreciate.
My driveshaft was cut at some point in its life and someone tried to weld it back together. They didn't do a very good job and it broke right at the cut/spot weld.
What I did was to go to the hardware store and buy a 4 inch length of 2 inch interior diameter galvanized pipe which fit over the driveshaft perfectly. Then I drilled 2 holes all the way through both the pipe and driveshaft at two different points perpendicular to each other. So that one bolt goes all the way through each end of the broken driveshaft. I don't really think I needed to but then I welded the new pipe to the driveshaft.
I haven't actually put it back in yet but it looks strong as hell and I bet its going to work great
Granted it won't be balanced but since I intend to change engines and trans soon I think it will be a perfect temporary fix so I can at least get the truck into the shop under its own power.
BookMan is offline   Reply With Quote
Old 09-20-2003, 04:37 PM   #2
jef5150
Inline 69
jef5150's Avatar
this "shop", is it on your property????
jef5150 is offline   Reply With Quote
Old 09-20-2003, 05:01 PM   #3
BookMan
yes but why? Are you sceptical about the fix?
Old 09-20-2003, 05:20 PM   #4
my new 72
faster, faster, faster
my new 72's Avatar
I am. Doesn't sound too safe to me.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 09-20-2003, 05:46 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
I agree with Josh. It should get you home, but I wouldn't drive it too much. I was okay with it until you mentioned the bolts. They'll do their best to vibrate loose.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-20-2003, 06:00 PM   #6
BookMan
I appreciate your concern. But this is my thinking. A previous owner shortened the front portion of the shaft and only welded it back together in one spot. That lasted for about 3K miles.
And - The pipe I used as a patch is at least twice as thick as the tubing of the driveshaft itself so my patch is stronger than the original.
And - Worst case scenario the bolts through the shaft break AND the welds break (which seems unlikely) and it comes apart again. That would most likely happen when I'm putting the most torque on the driveline - which would be starting from a stop. So most likely the only thing that would happen would be the short piece of shaft directly behind the trans would spin around bang against the bottom of the cab like it did before.
Admittedly the fix is not ideal because of the balance issue but for a savings of $98 its worth a try for a temporary fix.
Unless I'm not thinking about it correctly. What do you think?
Old 09-20-2003, 06:04 PM   #7
BookMan
Maybe you're right about the bolts trying to vibrate loose. I won't be driving it far. I'll be curious to see what they look like when I swap out the trans soon.
Old 09-20-2003, 09:18 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think I would slowly get it into the shop and get the shaft done right.
And this comeing from someone who drove his truck for 1 1/2 years with only front brakes.
Old 09-20-2003, 11:25 PM   #9
rage'nrat638
rage'nrat638's Avatar
ROFLMAF
rage'nrat638 is offline   Reply With Quote
Old 09-20-2003, 11:29 PM   #10
lukecp
Formerly yellow72custom
lukecp's Avatar
Yup....i would hesitate to drive it into a shop....just don't go over 10mph.
I have drove my truck 25 miles with a unbalanced driveshaft (i was an idiot and put it together out of phase when switching U-joints). I just took dirt roads and didn't go over 35mph
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-21-2003, 07:59 PM   #11
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Yeah, I agree with the others here. Just look at what happens when you make your own driveshaft repairs. This is my friends truck here: Clickey
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 09-22-2003, 12:44 AM   #12
Longhorn Man
HOLEY SHNIKEYS!!!!!!!
