Old 01-17-2016, 10:55 PM   #1
Joemomma1
Joemomma1's Avatar
How to install engine dipstick tube
During the process of trying different types of exhaust manifolds I had removed the oil tube and dipstick. Unable to find them I went to the wreckers and found one from a mid 70s caprice. It's exactly what I pulled out of mine but I cannot get it to seat all the way down. There is a slight gap between the block and flange of the dipstick tube causing a small leak. It fits snug while pushing it on but it's the last bit that won't go. The lower tube has not been removed. It never leaked with the old tube. I don't want to use silicone or something like that because it wasn't required before but do I have a choice? Is there a way to do this with the engine in the truck?
Joemomma1 is offline   Reply With Quote
Old 01-18-2016, 01:23 AM   #2
'63GENIII
'63GENIII's Avatar
Re: How to install engine dipstick tube
IIRC, on the small blocks that I had, there was a "pinched ring" on the dipstick which also worked as a stop. I would work a small drift around that ring just tapping my way around until it seated. It was somewhat of an interference fit. I would use a light skim of RTV to avoid any leakage.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
