Old 01-19-2016, 11:19 AM   #1
SnS C10
SnS C10's Avatar
Picking up this today
I saw an ad for a 77 c10 shortbed a guy was parting out. He didn't list the front complete front crossmember, but I asked if it was available. He said it was and how much do I offer. I said well, how about 100 bucks and he agreed
So he yanked it out yesterday and I'm picking it up today. Said I can have the steering gearbox as well. Is there anything else I should grab to do the crossmember swap on my 64 c10? Or basically just unbolt what I have and this new one fit right in with a couple holes being drilled/modified?
SnS C10 is offline   Reply With Quote
Old 01-19-2016, 11:50 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Picking up this today
That should be everything you need. I HIGHLY recommend CaptainFab steering box mount. You'll need that to mount the box correctly to your frame. If you already have your engine out of your truck, you can swap the whole crossmember in but in all honesty, all you need to do is swap the arms and steering. Crossmembers are basically the same and don't need to be swapped.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-19-2016, 11:56 AM   #3
SnS C10
SnS C10's Avatar
I currently do not have an engine. Which is easier to do, swap the whole thing at once, or just swap individual parts? No benefit in using the 77 crossmember?
Old 01-19-2016, 01:03 PM   #4
earl84
I did the whole crossmember, but that was mostly because I could easily transport it to the car wash for cleaning and subsequent priming/painting. I could also replace all the worn parts pretty easily, easy access. No real advantage to swapping crossmember out other than that, as far as I know.
I would highly recommend grabbing the sway bar and brackets as well. Grab the alignment shims as well. You will almost certainly need some of them to do an initial driveway alignment.
Second Captainfab's steering bracket, makes it so easy, and it's a quality piece and everything lines up perfectly, now tweaking, makes it easy.
earl84 is offline   Reply With Quote
Old 01-20-2016, 01:04 AM   #5
chevy_mike
chevy_mike's Avatar
If you don't know if the rubber bushings in the A arms have been replaced recently, you should pull it all apart to replace them. If you pull it apart to do that, there is no reason to remove the stock crossmember. If everything is in great shape, it would be easier to swap the whole thing.
Old 01-20-2016, 02:01 AM   #6
Captainfab
60-66 Nut
If you can get the rag joint if it is in good shape. Also the proportioning valve, hard lines and maybe the master cylinder if it appears to be in decent condition. If nothing else the master and prop valve will give you an idea how it is all plumbed.
Old 01-20-2016, 10:36 AM   #7
SnS C10
SnS C10's Avatar
I picked it up yesterday. It has all the brake lines, steering box, and the wheels. I just bought a new brake booster/master cylinder a few days ago. I will be buying the bracket for the steering and brake booster from you captainfab, soon. He also threw in the 2 front wheels and a 77 shortbed drives haft which I believe I can use for my project, everything was paid for 120. I couldn't believe the price...
Old 01-20-2016, 12:40 PM   #8
blown240
blown240's Avatar
Great Score!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
