01-19-2016, 10:53 PM | #1 |
3/8" schrader vavle source??
Anyone know a source for 3/8" push lock Schrader valves? I want to a way to manually fill my bags while I build my chassis. I stopped by my local parker hanafin store and have been scouring the net to no avail.
Thank you Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-19-2016, 11:12 PM | #2 |
Re: 3/8" schrader vavle source??
Try truckspring.com
01-20-2016, 12:01 AM | #3 |
They have them for 1/4 line but I don't see any for 3/8
Thanks Marc
01-20-2016, 12:31 AM | #4 |
I have never seen any for 3/8 line either.
01-20-2016, 09:06 AM | #5 |
OK good, I'm not crazy then. I assume people make them up with different fittings. I will report my findings for others.
Thanks Marc
01-20-2016, 09:36 AM | #6 |
Try Fastenal.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-20-2016, 02:20 PM | #7 |
01-20-2016, 08:18 PM | #8 |
Hello to all. This can't be to hard. Why don't you use adapters. The schrader valve will be 1/4 inch male or female. Use a male or female adapter for the push to connect fitting that goes to the 3/8 air line.
01-20-2016, 10:35 PM | #9 | |
Marc
01-20-2016, 11:32 PM | #10 |
Thursday morning, I'll check in the garage to see what I used. It definitely was a push to connect 3/8 tee with a male end that screwed into a female end that adapted to a 1/4 schrader valve. I will post pics asap.
01-21-2016, 12:27 AM | #11 |
Go to your local hardware store. I used a couple schraders with a series of adapters to get to the appropriate size. As far as setting it up to raise either the front or back together just use ptc to a ptc tee to a compression with a schrader. Doesn't have to be fancy if you plan on replacing anyways right?
01-21-2016, 01:03 AM | #12 |
Swagelok might have them
01-21-2016, 09:01 AM | #13 | ||
I plan on using these. They are the cheapest that I found. http://www.ebay.com/itm/310324104805...%3AMEBIDX%3AIT and http://www.ebay.com/itm/111603154912...%3AMEBIDX%3AIT Marc
01-21-2016, 09:53 AM | #14 | |
01-21-2016, 05:38 PM | #15 | |
Sorry too late. I was tired of looking so I pulled the trigger (prior to seeing your message). All in it was less than $20.00 (shipped). No bad. I already blew $70 on some Parker Hannifin fittings so whats another $20.00 ha ha I appreciate your gesture. Marc
01-21-2016, 05:40 PM | #16 |
No worries!
01-21-2016, 06:54 PM | #17 |
sorry for my late reply. here is a pic of what I used. the first pic is a Schrader valve for 1/4 air line. can you see my finger? the second pic shows how the adapter and the PTC fittings go together. The 3rd pic is how I used the 3/8 ptc fittings, adapter, and the Schrader valve. good luck and sorry for the late post.
01-22-2016, 07:02 PM | #18 |
Marc, when you get yours put together can you throw up a picture or two please? I may do the same.
01-25-2016, 11:40 PM | #19 | |
Marc
01-26-2016, 10:44 PM | #20 |
01-27-2016, 10:38 PM | #21 | ||
http://www.ebay.com/itm/310324104805...%3AMEBIDX%3AIT and http://www.ebay.com/itm/111603154912...%3AMEBIDX%3AIT Quote:
Marc
01-27-2016, 11:55 PM | #22 | |
I had just ordered a set of these for my set up......... |
01-27-2016, 10:46 PM | #23 |
Thanks Marc and Coach!
Ordered the schrader valves...hmm punched in 4...oh well. And ordered 2 of Coaches T recommendation.
Doug Advanced Designs 1977 Blazer Build Advanced Design's '48 'Burb Build Mrs Advanced Design's '72 Suburban Advanced Design's 56 BelAir LS swap Last edited by Advanced Design; 01-27-2016 at 11:02 PM. |
