01-20-2016, 01:14 PM | #1 |
radiator hoses LS swap
whats up guys... starting the mock up of the LS in the 67 what hoses are yall using for the swap...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
01-20-2016, 01:24 PM | #2 |
Re: radiator hoses LS swap
im doing the same thing in my 67 too. from what ive seen, most guys are using the same upper rad hose as the doner veh. .
or you can drop some $$$ and get a cust radiator with the top inlet on the passenger side
1967custom |
01-20-2016, 01:28 PM | #3 |
ya I have a ron davis radiator.. the top inlet is on the pass side.... just trying get an idea what hoses to grab.. this a crate LS3 so no donor hoses..im going to make a template today go hunting..
01-20-2016, 01:29 PM | #4 |
the boat guy
It depends on what water pump setup and radiator you are using.
5.3 truck engine/water pump with stock 67-72 radiator - 01 v8 silverado upper and part of my old upper for the lower.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-20-2016, 01:36 PM | #5 |
I got an "LSX" radiator with passenger side inlet and outlet. I made a upper and lower radiator hoses out of the upper radiator hose.
01-20-2016, 01:39 PM | #6 |
What hose did you use... do you have a part#
01-20-2016, 01:41 PM | #7 |
Probably I got a 2001 Suburban 1500 suburban hose or something similar.
