01-20-2016, 11:20 PM | #1 |
Help with 2500 Hd wheels
I am going to use some 2500 HD aluminum wheels on my C20 camper special. I thought I had this all figured out but I ran into an issue. My rear axle protrudes out to far to allow the use of the shallow factory center caps so I obtained two dually deep style center caps. Now the problem is that the dually caps are to big around at the base to mate up with the rim properly. in other words the cap doesn't quite reach the lug nuts so I cant anchor it. What do I need to do? is there another cap that I need to be looking for? Should I be looking at cutting down the caps? Longer wheel studs??? Please help.
Here are a few pictures to help clarify things. |
01-20-2016, 11:34 PM | #2 |
Re: Help with 2500 Hd wheels
I have those wheels on my 68'.I had no problems with the way they fit.Don't know if the rear end in the later trucks is different where the cap mounts and would cause interference or not. I will look at mine a little closer tomorrow.
01-20-2016, 11:49 PM | #3 | |
01-21-2016, 12:25 AM | #4 |
May be the difference from a full floating Eaton and a Dana 60?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-21-2016, 12:34 AM | #5 |
01-21-2016, 07:58 AM | #6 |
I can't speak for why your caps won't fit off the truck, but like everyone else said, it is because you have a Dana 60 rear, right?
My truck below had a factory Dana 60 rear and the center caps would not fit. The FF hub sticks out further on the 60 than on the Eaton. I swapped a late model 14 bolt in mine and everything went together. Hope this helps. And those center caps aren't held on too secure with those cheap plastic lug nuts in my opinion! Barnfind- Nice truck!!! I like it!!! BBB |
01-21-2016, 08:21 AM | #7 | |
01-21-2016, 08:53 AM | #8 |
That's the reason the caps won't fit depth wise, you have a Dana 60.
I suspect that the reason the dually caps won't fit, is because the dually wheels are entirely different and must have a greater dish around the lug nuts. Your truck appears to also be factory rear leaf springs, just like mine. What is yours geared? Mine was 4.56, and that is the reason for the 14 bolt swap. To get some more highway friendly gearing. FYI and you may already know this. A late model (73-up) 14 bolt is almost a direct bolt in. You just have to move one shock mount and get longer e-brake cables. I really like your truck, I'm kinda partial to the 3/4 tons! HAHA!!! Got any pics of the whole truck? BBB |
01-23-2016, 03:04 PM | #9 |
I believe there are 2 different caps, ones for the steel wheels and ones for the aluminum wheels. Only a slight difference where they fit to the wheel. I bet you have a set for the steel wheels. Check that out and see.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
01-23-2016, 07:45 PM | #10 |
All about them K’s
This is 100% true. I went thru this when swapping from gmc caps to Chevy caps on my brother in laws 06 2500hd. We got a cheap set of OE Chevy caps from Craigslist and fought and fought with them. I finally got to comparing part numbers and there are 2 indeed different caps. I'm sure a belt sander would probably fix the issue pretty easy.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-22-2016, 07:01 AM | #11 |
Deadshort52, I can't help you. But I have a dana 60 and used to have those tims on a 2003 GMC HD1500. I have never seen them painted white. I like that look. Reminds me of the white steel, but fancier. Can you post a picture of the front wheel with chrome cap on? I would like to see the finished look.
1966 GMC 1500 (3/4 ton) Custom V6 3sp Edna 1970 GMC C2500 Deluxe lwb 307/4sp Ol' Green 1971 Chevy C20 Custom lwb 307/3OTT, now a project in family since 1974 2014 GMC K2500 Crewcab 6.0 gas 2005 GMC Canyon Ext cab 4wd daily driver 1963 F*rd/Howe C750 fire truck 11,000 miles |
01-22-2016, 08:56 AM | #12 |
I had the same problem. I took my sawzall and cut about 1/4 inch off the back edge of the caps. this allowed them to bolt on. when installed you cannot tell they are cut.
01-23-2016, 12:21 AM | #13 | |
Here are some pictures. I am going to fire up the Dremel tool and the belt sander tomorrow to get the caps to fit. If that fails I am going to order some spacers to move the rear wheels out so I can use the shallow caps like the front ones. I really like the stock look with the white steel wheels and the hubcaps but my hubcaps are bad and I am sick of looking for a good set. I decided to powder coat a set of these and leave the caps chrome and paint the bowtie emblem blue for the older look. What do you guys think? Thumbs up or thumbs down? |
01-23-2016, 12:44 AM | #14 |
I like the spacer idea for the rear. Shouldn't have to be too thick, but from your pics I think you'd need longer studs.
Here are the same caps on my Hummer wheels modified to mimic the original hubcaps. |
01-23-2016, 11:20 AM | #15 |
01-23-2016, 01:06 PM | #16 |
i really like those wheels and they look great white.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-23-2016, 04:36 PM | #17 |
See post 255 in this thread for details on the cap modification. Additional pics in post 250
http://67-72chevytrucks.com/vboard/s...330740&page=11 Be aware that the 1997-2003 Malibu bowtie alone is not large enough to cover the gold bowtie on the caps. These Malibus are very plentiful in the junkyard near me. My truck has an Eaton rear end, and the caps fit fine. As Joesjunk said in post 21 above, the steel wheel caps do not quite seat properly on the 2500HD alloy wheels, but I don't believe that alone would affect the fitment problem with the Dana axle. The alloy wheel caps have bulges/bumps around the circumference at the lug nut locations that are also visible in post 255 in the link above, whereas the steel wheel caps are smooth around the circumference. Last edited by FirstOwner69; 01-23-2016 at 04:48 PM. |
01-22-2016, 11:27 AM | #18 |
I was just thinking the other day of powdercoating a set of those white for my C20. I like the look, but I have a Dana as well so I'll have the same issue.
1971 Chevy Custom Camper/20, Hugger Orange with White Top 31,000 original miles (when purchased), 402, TH400, PS, PB, AC As of May 2017 it now has a turbo LS in it! (Still looks stock though) |
01-22-2016, 04:58 PM | #19 |
Those wheels look nice in white I have a Dana 60 with Dually caps on it. First pic should be the front wheel..second pic is rear wheel... Had to trim them to fit...
72 C20 Longbed 05 1500 Z71 |
01-23-2016, 03:09 PM | #20 |
Wish I'd seen this thread earlier! I did the same thing with those same center caps on my own Dana 60.
I went the spacer route. I think wheel adapters are bad mojo but spacers are OK. I forget if I wound up needing one or both, but I ordered 4 half-inch ones off eBay (I think). I figure 8 bolts is plenty in double-shear. Anyhow, solved it for me. I have mine where the cap is still right up against the hub, it's tight. This also serves to broaden the rear track and make it closer to the front, which is inexplicably wider on these trucks. Depending on your studs and spacers, you might need new studs. I had to lengthen mine to get proper engagement. I also drilled mine out and replaced them with 9/16" to match the '72 fronts I installed, so if they look a little bigger, that's why.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
