Old 01-21-2016, 12:58 AM   #1
dracko
dracko's Avatar
Upper control arm spacers
I recently rebuilt an '85 crossmember to put on my '64.
These 4 spacers were behind the upper control arms and looked to be factory installed. 2 are thicker and I'm wondering how these should be reinstalled on the bolts. Any help appreciated.
dracko is offline   Reply With Quote
Old 01-21-2016, 03:08 PM   #2
jetmech85
Re: Upper control arm spacers
The thicker ones go on the aft bolts and the flat surface goes outboard. Mine is not apart but appears that the rounded surface may fit into a depression on the crossmember then adjustment shims onto the flat surface. Hope this helps.
jetmech85 is offline   Reply With Quote
Old 01-22-2016, 12:22 PM   #3
dracko
dracko's Avatar
Thanks for the info. These are flat on both sides, I noticed the ones that came off the 64 have a dished spacer that pivots on a crowned spacer.
These trucks look to have a crowned rectangular washer that was over these flat ones.
Old 01-22-2016, 01:37 PM   #4
Jaysonb
Jaysonb's Avatar
These slide on first, then the alignment shims, then the rectangle spacers that fit into the control arm shaft. The thick one goes to the rear. I have my frame sitting bare, so I just ran out and snapped a pic for you. Hope this helps.
Jaysonb is offline   Reply With Quote
Old 01-22-2016, 04:32 PM   #5
dracko
dracko's Avatar
Thanks very much Jayson! Exactly the info needed to finish putting this crossmember together.
