Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-25-2016, 01:06 PM   #1
GMCNUT
GMCNUT's Avatar
WTB: uncut 64-66 GMC underdash wiring harness
I need to find someone who's got an un-molested original parts truck on their property that is a 64-66 GMC (cannot be out of a Chevy) 1/2 ton, 3/4 ton, 1 ton, 2 ton - all GMC trucks have this harness it connects the cluster to the ignition and headlight / dimmer switches and connects to the big plug in the firewall near the drivers side and the smaller firewall plug for the engine harness to connect to. Would like to buy one that also has its original ignition switch and key if possible.
Please look and see what you may have - gotta be one out there thats not got melted or cut on wires - text or call me at 256 486 1988 Thanks, Steve
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-25-2016, 05:30 PM   #2
shortstep60
Re: WTB: uncut 64-66 GMC underdash wiring harness
I will check for you I no there one on the truck but I don't no how good it is I will let you no in a couple days
shortstep60 is offline   Reply With Quote
Old 02-16-2016, 05:20 AM   #3
kerber63
kerber63's Avatar
I've got one that I just pulled today. Has everything except for ignition switch and key. All wires are flexible - no burns or hard spots. Rubber grommets are nice and soft. I cut 2 grounds and the fuel sender wire. PM me if you're interested.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
