Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-25-2016, 02:58 PM   #1
383 Stroker
383 Stroker's Avatar
Moog 81114 Front Springs
If any of y'all are looking for a longer front spring with a lower spring rate that will maintain the ride height of a stock spring, check out the Moog 81114.... I cut half a coil off to get the ride height the same as the stock Moog 6082.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 01-26-2016, 07:11 PM   #2
hjewell2
hjewell2's Avatar
Re: Moog 81114 Front Springs
Does it have enough stored energy for a good launch.
hjewell2 is offline   Reply With Quote
Old 01-26-2016, 10:00 PM   #3
383 Stroker
I'll find out this weekend if they work any better... it's a lot easier to lift the front of the truck now. I can grab the fender by hand and lift it to full suspension travel.
Old 02-02-2016, 08:25 PM   #4
383 Stroker
The springs helped. Got a 1.53 60ft
Old 02-03-2016, 06:46 PM   #5
hjewell2
hjewell2's Avatar
awesome lift I'm sold on these springs
Old 02-03-2016, 06:53 PM   #6
383 Stroker
Just measured it. 10" installed.
Old 02-03-2016, 02:31 AM   #7
Super73
Super73's Avatar
Did you by chance measure free height before installing?
Do you know what the front of your truck weighs?
Are you willing to measure installed height?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-03-2016, 12:52 PM   #8
Ont67shortbox
would those work with a BBC without cutting a coil
Ont67shortbox is offline   Reply With Quote
Old 02-03-2016, 05:47 PM   #9
383 Stroker
Here's the specs on the 81114 springs
Old 02-03-2016, 05:54 PM   #10
383 Stroker
I didn't measure them, but they're suppose to be 16.74" free height. The front of my truck weighs 2257lbs. It's around 10" installed with the half coil cut. It would probably work with a big block if you have stock spindles. I have 3" drop spindles.
Old 02-03-2016, 06:00 PM   #11
383 Stroker
Here's the springs installed
Old 03-31-2016, 10:53 PM   #12
dustin72
dustin72's Avatar
Any updates on these springs? Thinking about ordering a set for my truck. Currently have 2.5" drop spindles and 2" lowering springs. Hoping these will keep my current ride height with my BBC. Need more weight transfer.
dustin72 is offline   Reply With Quote
Old 04-01-2016, 02:14 AM   #13
Super73
Super73's Avatar
Dustin,
IMO if you have not weighed your truck (front and rear), consider it. That will help determine the right spring.
Old 04-05-2016, 08:57 PM   #14
c10-72 II
Active Member
c10-72 II's Avatar
Is it necessary to cut the coil? What would be the difference if you didn't? Building a 68 c10 with a small block. Rebuilding the front end, wondering what the difference would be if I didn't cut these springs. Thanks.
c10-72 II is offline   Reply With Quote
Old 05-10-2016, 10:43 PM   #15
Jrgunn5150
Interesting, those springs are Trailblazer springs. I DD a Trailblazer, with those springs for a little more lift.
They also offer a 81110 and 81112, the only difference being the free length. The rate is the same on all, here they are on my Trailblazer, which has a different mission lol.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 05-29-2016, 11:38 PM   #16
dustin72
dustin72's Avatar
Just an update on these springs. Finally got them installed on my truck. I didn't cut any coils and had a hell of a time getting them in, but they sit at 28.5" ground to fender lip with 2.5" drop spindles and a BBC. I expect them to settle to around 28". My old Belltech 2" drop springs had the truck sitting at 28", so these worked perfect for me. They made a huge difference in the weight transfer of the truck. We had our first race of the season at our local airport this weekend with minor track prep and had the truck running 1.64 60fts. This is pretty good for the first race of the year with not much rubber on the track yet. Anyways I would strongly recommend these springs if you want to get your truck to transfer. Here are a couple pics:
Old 05-30-2016, 04:11 PM   #17
69GMC910
MOTORHEAD!
69GMC910's Avatar
Will these springs also fit the square bodies?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 05-30-2016, 08:32 PM   #18
dustin72
dustin72's Avatar
Yes, since the suspensions are basically the same.
Old 06-01-2016, 12:56 PM   #19
383 Stroker
I installed them on a friends square body. Its a small block truck with stock spindles.
Old 07-27-2016, 10:50 PM   #20
c-man405
Would it be possible for you to measure the ground to fender lip? I want to try these but don't know how much they will affect the ride height. Also what's done do the rear suspension?
Thanks for any information.
c-man405 is offline   Reply With Quote
Old 07-28-2016, 06:38 PM   #21
c-man405
Also I should add how have they changed weight transfer and street driving?
Thanks again Carter
Old 05-31-2016, 10:06 PM   #22
19671972C10
I need to get those springs since i swapped to 468BBC.
19671972C10 is offline   Reply With Quote
Old 05-31-2016, 10:12 PM   #23
Jrgunn5150
Like I mentioned, they make the 10's and 12's also, if you guy's need a little less height.
J.R.
Old 06-01-2016, 12:50 AM   #24
dustin72
dustin72's Avatar
The 81114's sit like a 2" drop spring in my BBC application with no cutting.
Old 06-01-2016, 02:17 PM   #25
69GMC910
MOTORHEAD!
69GMC910's Avatar
Well I'm sold!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
