01-26-2016, 04:42 PM | #1 |
Millermatic 90 vs Lincoln Mig Pak10
I have had a Mig Pak10 for about 5 years. Like it.
Always told that Millers are much nicer. I found a Millermatic 90 used (broken) on the local forsale forum. Got it for $150. Traced the issues and it will need a new fan. So its going to be about $250 for the welder all in. The spec's on the two welders are virtually identical; 90ish amps each, 20% duty each, 18VDC. The miller is 80lbs, and the Lincoln is just 48lbs. Also the Miller has 5-80ipm vs the lincolns 50-300 ipm (wire feed rate). Any thoughts on which one to keep? I am torn between, the lincolns newer, very clean appearance, and the Millers - been around for ages... Thoughts?
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
01-27-2016, 01:30 AM | #2 |
Re: Millermatic 90 vs Lincoln Mig Pak10
5ipm doesn't sound right to me. A high of 80 sounds awfully low too.
I'd try running both and see which one you prefer. I suspect you'd be better off buying both and picking up something a little bigger, with gas.
1973 C20, 350/350 |
01-27-2016, 08:44 AM | #3 |
Sorry I miss typed that. The Miller spec in the manual is 5-800 ipm.
I am going to pickup the new fan today, and try a "weld-off" this weekend some time...
