Old 01-26-2016, 07:04 PM   #1
gridironkohn
gridironkohn's Avatar
Original dash repair
After reading reviews and taking input from message boards I decided replacing replacing my destroyed dash pad on my 85 k10 was inevitable. But I also learned that one I did not want to go the dash pad cover way (too cheap if a look and too easy lol) and two the aftermarket options were ok but not ideal fitnent or quality when comparing to the OEM dash pad with the metal bracing. So I lucked out and found one on Craigslist for $60! All but two metal clips were intact which won't be a problem since I took the ones from mine off. There were 2 cracks but legitimate cracks. But after reading about the dash pad filler product by urethane supply company I decided to tackle the project 👍. I mean why not??? $60 plus $25 in supply's it is worth it. Anyway here is a little progress so far once I go back in the house and post pics from the pc
gridironkohn is offline   Reply With Quote
Old 01-26-2016, 08:21 PM   #2
gridironkohn
Re: Original dash repair
before:
Old 01-26-2016, 08:27 PM   #3
gridironkohn
Time for the Dash pad filler:
I spread it on kind of heavy. I then knocked down the high spots with a small putty knife. The filler is much like JB Weld in that it is a two part. With one small tube of hardener.
Old 01-26-2016, 08:35 PM   #4
gridironkohn
Now time to sand it down. Again I used a small putty knife to spread it on but also used that same knife to knock off the high spots much like when you do your first coat of drywall mud. I then lightly used a 60 grit to further knock it down. Then finished with a 220 grit on a sanding block. I liked the results but as I though the perforated holes for the speakers did not work out so well. I used a drill bit to recreate the holes but in the spots where the cracks were it didn't seem to take hold in between. I think now I will need to apply some filler underneath to strengthen it then let it dry and then drill. Although I did find that if I dabbed the holes with the drill bit while applying it wet I was able to secure a good hole pre sanding. We will see!
Old 01-26-2016, 08:39 PM   #5
gridironkohn
I will be applying a 2nd very small coat. I can still slightly see the crack. But so far I love this product. Sands very easy like fiberglass. And did not take very long. Spent maybe 2 hours total so far on it.
Old 01-26-2016, 09:08 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Thanks for the pics, I've been wondering how well that works. What are you using for a texture coat?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-26-2016, 09:29 PM   #7
tommy217xxx
tommy217xxx's Avatar
That's awesome and hello fell Michigan square body lover. I'm workin on mine also but I'm goin a little different route. I'm following this method.
http://www.gm***************/forum/s...ead.php?t=8614
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 01-26-2016, 09:41 PM   #8
gridironkohn
link isnt working for me
Old 01-26-2016, 10:00 PM   #9
tommy217xxx
I'm sure why. It's over at gmsquarebody under the interior section pinned to the top. Also why can't in paste a link to that site?
TJ
80 Chevy c10 lwb
305/350
Old 01-26-2016, 10:15 PM   #10
gridironkohn
damn still cant find it. Pretty sure you can click on the link icon and copy and paste to it. shrug. But Im the new guy! so dont qoute me on it. And greeting fellow michigander!
Old 01-26-2016, 10:47 PM   #11
gridironkohn
I found it brother! I finally realized it was a different message board all together. Nice work man your was pretty rough. I wish I had not thrown mine to the trash now grrrrr. My original one that is. But I am definitely happy I went with the dash I found. The lost important thing to me was a dash that looked exacly like the original. Meaning all the same grill holes. This may end up as a show truck who knows! Plus I wanted the added challenge of fixing the cracks along the holes. Why I do this to myself I dont know smh
Old 01-26-2016, 11:13 PM   #12
tommy217xxx
Oh that's just the one I'm fallowing. That's definitely not mine. Lol
TJ
80 Chevy c10 lwb
305/350
Old 01-27-2016, 12:36 AM   #13
gridironkohn
Oh you didn't call great stuff gap and crack filler??? Lmao! Ah I got ha now. Yeah not a bad way to fix it. But I saw allot of flaws. I'm hoping mine looks damn near perfect...we will see soon enough. Hope to add the texture tomorrow
Old 01-27-2016, 07:01 AM   #14
Trust_me
Beautiful , I thought i can repair it
Trust_me is offline   Reply With Quote
Old 01-27-2016, 11:53 AM   #15
tommy217xxx
I think the expansion foam would work good if u needed to fill in chunks of missing foam. The dash pad filler looks good for the 2nd layer then the texture. I need to do my beat up door panels to. I'm just at the fiberglassing stage.
TJ
80 Chevy c10 lwb
305/350
Old 01-29-2016, 11:25 PM   #16
tommy217xxx
Hey grid, how's the pad comin? I jumped into mine and I just got done sanding the foam. I decided to fill in all 3 speaker holes b/c they were all a little rough.
TJ
80 Chevy c10 lwb
305/350
Old 01-30-2016, 12:45 AM   #17
gridironkohn
Unfortunately I haven't done anymore work. Got busy at work and family stuff. Hope to spend some time on it tomorrow! Yeah I still may cover the middle speaker hole. But I'm gonna give it my best shot first. Look forward to it
Old 01-30-2016, 10:57 PM   #18
tommy217xxx
Hey where did u get the dash filler? Was it a local place or did u have to order it?
TJ
80 Chevy c10 lwb
305/350
Old 01-31-2016, 01:43 PM   #19
gridironkohn
From urethane supply co. Online. Was $16 plus shipping but you will need the texture spray and adhesion promotor for the coating before the texture. I ordered everything but the promotor online. I'm leaving now to get the promotor from auto zone . I will be posting pics real soon of the progress today!
Old 01-31-2016, 09:07 PM   #20
05duramaxhd
that turned out nice!
05duramaxhd is offline   Reply With Quote
Old 01-31-2016, 09:42 PM   #21
gridironkohn
Thanks guys. Next is paint! Still have not decided if I want to paint it the blue the truck will be or just satin black
Old 01-31-2016, 09:50 PM   #22
TKCR
TKCR's Avatar
That looks like a brand new pad!! You did good!!
Old 01-31-2016, 10:25 PM   #23
gridironkohn
Thanks but I'm not completely satisfied yet. I see little flaws still but think a 3rd coat of texture will solve it. Plus the paint and might even matte clear it.
Old 01-31-2016, 10:40 PM   #24
68Timber
68Timber's Avatar
Man that looks great! One vote for blue here, just to see how original/factory this repair can go.
John
74 Honda Z50 build
Old 01-31-2016, 10:54 PM   #25
gridironkohn
Yeah Im leaning towards blue. One thing is for sure. I need to make that decision fairly quickly. The texture coat is easily marked up. Unless I wrap it up and keep it stored away safely. Here is the color my truck will be. Just the inside of my door.
Graphite Blue metallic.
