01-28-2016, 03:34 PM | #1 |
Go Pack Go!
Rear gear ratio question
HO-52 with the following:
3682104 GM 7-32 1.54 Is this 4.57 ratio? 32 divided by 7? |
01-28-2016, 03:40 PM | #2 |
Re: Rear gear ratio question
Here you go... from SSTim originally I believe. Search is your friend :-) 3682104 decodes to the 32/7 4.57 ratio as you thought.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-28-2016, 04:31 PM | #3 |
The Older Generation
Rear Axle Ratios Ratio 2.56:1 - Tooth Combination 41,16 Ratio 2.73:1 - Tooth Combination 41,15 Ratio 3.07:1 - Tooth Combination 43,14 Ratio 3.08:1 - Tooth Combination 40,13 Ratio 3.08:1 - Tooth Combination 37,12 Ratio 3.31:1 - Tooth Combination 43,13 Ratio 3.36:1 - Tooth Combination 37,11 Ratio 3.42:1 - Tooth Combination 41,12 Ratio 3.55:1 - Tooth Combination 39,11 Ratio 3.73:1 - Tooth Combination 41,11 Ratio 4.10:1 - Tooth Combination 41,10 Ratio 4.11:1 - Tooth Combination 37, 9 Ratio 4.57:1 - Tooth Combination 32, 7 The tooth combination numbers will be found stamped into the ring gear when you take the back cover off. These may not all be for the trucks. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-28-2016 at 04:50 PM. |
01-28-2016, 04:53 PM | #4 |
Go Pack Go!
Awesome, thanks for the info. Now to find a 4:11
