01-31-2016, 09:31 PM | #1 |
compatibility question.
To start, I apologize for what is probably a very simple question. I'm new to the Chevy world. Was wondering what other Chevy trucks I can pull from for my 1973 Cheyenne k10?
Found this book "1973-1987 GMC and Chevy Truck Parts Interchange Manual" but wanted to get a jump start on junkyard picking. Thank you.
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
01-31-2016, 09:59 PM | #2 |
Re: compatibility question.
73-87 are for the most part the same from the cab back. 80 has square headlights but other than that the same as 73-79. 81-87 have a different front clip. There are slight differences through out the years so check specific parts for compatibility. Grab an lmc catalog. Pretty good info
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
01-31-2016, 10:03 PM | #3 | |
02-01-2016, 08:21 AM | #4 |
Don't limit yourself to picking just trucks. A lot of GM car parts will work as well, especially if you want function over form. I have a Blazer steering wheel and a Spectrum rear view mirror in my 75. The Pontiac steering wheel would have worked mechanically, but didn't match the style of the column as well as the Blazer one did. My THERMAC temp sensor was taken from a generic GM car. Pulled a 12SI alternator out of a GM car as well, just needed to swap the mounting bracket and clock the alternator.
02-02-2016, 10:44 AM | #5 |
There are a few things to be careful of. Door insides changed quite a bit for a few years around the time power windows were introduced. Glass thickness and window vents had variations. Fuse boxes changed from glass tubes to newer design at one point. For power steering, check that tubing has same threads before attempting to fit. Otherwise there is a lot of interchange. Induction and ignition changed. Points to HEI early on, Carb to low pressure efi at the very end of the run. The efi was actually pretty decent. Suburbans and 1 tons kept the squarebody a few years longer. If wanting to change around frontends, it is usually good to get the radiator support as well as front body panels and hood, since they changed too. Those are some of the things that it seems that people tend to ask about. The best way to get up to speed is to spend a few days reading old threads. The longer ones tend to be common issues.This forum seems to be unusually helpful and supportive, but occasionally someone might express a bit of frustration if something has been addressed to death before, but the poster didn't feel it was worth their time to look it up themselves. For any real abuse though, these guys are too mature to really get creative about it. Pirate 4 by 4 is probably the best place to go to get abusive answers to questions, legitimate or not, but occasionally somebody there really knows their drivetrains. Half the time however, some dude will submit a reply designed to make somebody feel pathetic for not having Dana series 280 differentials and 50 inch tires This forum is unusually supportive. I have asked some really basic questions, and have only gotten great insight here.
jjmorrse 86 C30 crewcab big dooley. 454- 400 Last edited by jjmorrse; 02-02-2016 at 10:55 AM. |
