02-01-2016, 11:39 AM | #1 |
Routing Fuel Lines
I am trying to decide the best approach for routing the fuel lines on my 70 SWB C10 using a Boyd tank with the in tank pump. I plan to use braided PTFE line and I may or may not incorporate some hard line to help reduce the cost.
The Boyd tank was installed when I had my SBC, and I used hard line from the tank all the way to the mechanical pump along with 2 short pieces of rubber hose to make the transition from the tank to the frame and from the frame to the pump. At the time, it made more sense to run the line along the passenger side of the frame and my exhaust down the driver side. With the LS, it seems like the supply and return would be easier to route down the driver side, but moving my exhaust isn't really an option and I am not so sure I like the fuel lines running close to the exhaust. How is everyone else routing their fuel lines and would you have done it differently? |
02-01-2016, 12:34 PM | #2 |
Re: Routing Fuel Lines
I haven't done it personally, but I have seen it in other build threads. I think you can flip the fuel rail on certain intakes. Then the fuel fittings are on the passenger side. Try googling around. I don't which intake you have.
1968 Chevy C20 |
02-01-2016, 01:41 PM | #3 |
I think that would put the fuel lines at the front of the engine. I'd have to look at the placement to see if that makes things any better
02-01-2016, 04:49 PM | #4 |
I routed my lines down the passenger side, and used the OEM type nylon lines. I came up the firewall, and around the back of the engine to the fuel rail. Wrapped the fuel lines in a heatshield sleeve and haven't had an issue.
02-01-2016, 06:05 PM | #5 |
meowMEOWmeowMEOW
"technically" speaking the way to do it would be to lift the cab off the mounts and run the fuel lines OVER the frame, which is more common on late model trucks that don't have full C or I channel frames.
I have my fuel running on the inside of the passenger rail, ~4" or less from the exhaust. Its liquid fuel under pressure, not vapor, so the exhaust heat isn't a threat. Your not going to boil fuel unless you set the damn line right on the exhaust. If you REALLY think that your getting overheated fuel, just put a fuel cooler on the firewall (I've yet to see anyone NEED to actually do that). Heck, Honda guys still think pre-heating fuel is good (half joking, but check out some of the late 80's early 90's imports running fuel pre-heat....they like to blow up).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-01-2016, 08:40 PM | #6 | |
Any reason why you picked the passenger side over the driver side? |
02-01-2016, 09:05 PM | #7 | |
The fuel supply line came off! It had unhooked itself from the fuel rail and was hanging on by 1/2". Thankfully the engine still ran...enough so to manage an exit and a stop alongside the road. I knew something had gone wrong immediately because the cabin filled with the smell of fuel. I had shut the motor down as soon as I could and coasted to the side of the highway. I popped the hood and gas was everywhere. Those Walbro 255 pumps really do a good job at delivering the fuel! Well, I tried to reconnect it but it popped off again. Thankfully I had a FI clamp and that got me home but I was ever so thankful that there was no fire. God was really watching out for me! Anyway, I bought few fittings on Ebay that used a threaded cam setup to reconnect the fittings to the fuel rail. It is this one: http://www.ebay.com/itm/131404860888...%3AMEBIDX%3AIT and it works great. It may be a bit much @ $13.29 but it is insurance against a fuel fire. I would recommend using these not only on your fuel rails but on your fuel filter if you use the 3/8" OEM style filter. Hope this helps someone out there who is considering the OEM style fuel rail and fuel filter connectors. Simply said...they suck...kind of like the exhaust manifold bolts that GM never addressed. That is another peeve... Best to you all...especially Jonathan who sent me an engine cover bracket. Y'all, Jonathan sent it to me...no payment, no shipping, no nothing. He is a good man! John
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
02-01-2016, 09:34 PM | #8 |
why not run your line on the out side of the frame that will keep it away from your exhaust I have ben wondering im using a corvette fuel filter w/belt in regular can I put it by the tank so I only run one line up to the fuel rail ??
02-01-2016, 10:35 PM | #9 |
I mostly wrapped the lines as it does pass fairly close to the exhaust as it heads up the firewall, and it's nylon line. Likely overkill but it was cheap insurance.
02-02-2016, 01:32 AM | #10 | ||
meowMEOWmeowMEOW
Since the frame is a channel, most folks run it inside so its out of the way. On the outside of the rail, you'd have a fairly visible set of lines and a filter. Mechanically thats fine, just not really visually appealing.
02-01-2016, 09:25 PM | #11 |
I am going to run my fuel lines on the passenger side as the return less rail points straight back towards the firewall pretty close to the the engine centreline but more because the master/booster is on the drivers side and those lines will run down the drivers side.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
02-02-2016, 12:01 PM | #12 |
Boosted Member
I would do a stainless or aluminum hard line in the areas where it gets close to the exhaust.
I ran my feed on the driver side, and return on the passenger side, all hard line, with braided hose at the connections.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-23-2018, 11:55 PM | #13 |
Do you think it would be ok to run the exhaust down a long the fuel lines? I am running hard lines like yours down the frame thats boxed so the exhaust pipes will be 1.5-2" away from the fuel line going down the frame. Everything is getting really close together the more I build my truck.
02-02-2016, 01:29 PM | #14 |
wasted income? what is the k&n cylinder on the passenger frame rail?
1967custom |
02-03-2016, 10:33 AM | #15 |
I ran mine with hard SS line down the drivers side frame rail and used Russell Proclassic hose from the frame rail to the engine. I built heat shields and welded them to the exhaust. I also bought Thermo Tec adhesive insulation and stuck a couple of layers on top of the heat shields. I used this same method for my transmission lines as well.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
02-03-2016, 10:47 AM | #16 |
Boosted Member
It's a 25 micron filter. I've also got a 100 micron filter between the tank and the pump.
