Old 02-01-2016, 05:24 PM   #1
72MARIO
72MARIO's Avatar
hummer vs GM hot rod pan ?
I cant find a definite answer on the web I have looked and looked. I found a hummer oil pan kit thru GM parts direct Canada
http://www.gmpartsdepot.ca/p/Chevrol.../12624621.html total shipped with tax is $198.88 That Canadian money the US dollar cost me over $1.44 CAN
The above does not include the dipstick 12603506 or tube 12584738 same as the as the 6.2 ctsv pan ( That's an additional $44)
This is the kit hummer pan kit
http://www.gmpartsdirect.com/oe-gm/12624621
Cost $113.00
Are they the same pans for sure ??? Hot ROD vs Hummer ?
Just looking for a cheaper option over the ctsv pan its $411.00 Canadian shipped the hummer pan complete with stickand tube is $220 If i can save $190 that would be great.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-01-2016, 05:59 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: hummer vs GM hot rod pan ?
Both should be the "Lh8" pan (code for V8 Hummer H3's), the hot rod pan is the same thing. Mine came with the pickup tube and tray and was under $150 us.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-01-2016, 08:05 PM   #3
72MARIO
72MARIO's Avatar
Thanks for the clarification
What did you use for the dipstick and tube ?
2005 TAHOE DD
Old 02-02-2016, 02:16 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its so long ago now that I don't even remember. You might see it listed in my build 2-3 pages or so in, otherwise I'll pull out my paper records at some point and see if I can find it (might be a while, I gotta dig out my archives).
Old 02-02-2016, 03:53 AM   #5
ls1nova71
ls1nova71's Avatar
My GM hot rod pan came with a dipstick and tube, I thought they all did?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-02-2016, 07:31 PM   #6
crazy longhorn
Fabricate till you "puke"
Yup, mine cam the same way....pan/gasket/bolts/dip & pickup tube & the tray. The tray was not needed, as the truck pc fit US, through Summit or Jegs, was right at 150 bones. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-02-2016, 09:13 PM   #7
72MARIO
72MARIO's Avatar
Thanks for the clarification. I cant seam to find the hot rod pan kit here in ontario reasonable. I did find the hummer pan kit that includes everything but the dilstick and tube. So i am going that route its $242 canadian taxes in and shipped.
2005 TAHOE DD
