Old 09-21-2003, 10:05 PM   #1
krazy_texan
krazy_texan's Avatar
fuse block
i am going to be putting electric locks and windows in my truck within the next 6 months and was wondering if it is possible to use the fuse block and wiring harnesses out of a later model truck with power windows and locks and blade type fuses to make the installation of windows and locks and everything else easier to work with and more up to date, What i am doing is using a stock look with modern conviences, what do yall think
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 09-22-2003, 12:16 AM   #2
krazy_texan
ttt
Krazy Texan
1990 v1500 suburban
Old 09-22-2003, 01:04 AM   #3
aesj2
Anything will work given enough time and money. Check out Painless Wiring, they may have an updated wiring harness perfect for your 71.
aesj2 is offline   Reply With Quote
Old 09-22-2003, 01:32 AM   #4
Injected68LS1
Injected68LS1's Avatar
Anything can be done. If you had a stock wire harness diagram you easily convert a new fuse panel to work. You would have to be fairly good at wiring and soldering for something reliable. Also, you would have to modify how the fuse box would connect into the harness on the engine-side of the firewall. That would be the tricky part in my opinion.
When I installed my LS1 into my truck, I installed a aux. fuse block. It is on the heater box just below the glove box. I used this to fuse my coils, injectors, computer, fan, and fuel pump. I just ran a separate power wire from my battery to the fuse panel. I think it was an 8 gauge wire or bigger. This might be an easier option for you and you still get the blade-type fuses.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 09-22-2003, 01:38 AM   #5
Richard
What you might think about doing is add an auxiliary fuse block next to the factory block. Run a 10ga. wire directly from the battery to the new unit and you can swith part of it with a relay connected to the ignition.
Richard
Old 09-22-2003, 02:03 AM   #6
krazy_texan
i am wanting to rewire the whole truck except for the rear end i am thinking that a harness out of a mid 80's truck would work just change out the pigtails if needed but using the harness just as if it where in the truck that it belonged.
Krazy Texan
1990 v1500 suburban
