Old 02-02-2016, 07:53 PM   #1
Az. Hank
Az. Hank's Avatar
Shockwaves
Is there any alternative to shockwaves? Knockoffs that are any good?
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 02-02-2016, 09:08 PM   #2
joedoh
joedoh's Avatar
Re: Shockwaves
what are you trying to do? airbags to layout or just lower a little but not layout? lots of guys want shockwaves as the easy way to lay out but they only have about 4 inches of travel and are really sensitive to being bottomed out
Old 02-02-2016, 10:08 PM   #3
Az. Hank
Az. Hank's Avatar
Re: Shockwaves
I'm doing a 55 Chevy truck. C4 Corvette suspension. I want to blow the bags when I park it and lay it on the ground. I only need about 4" to drop it . My build is in my signiture below.
My 55 Build 55 C-4
Old 02-02-2016, 10:37 PM   #4
joedoh
joedoh's Avatar
Re: Shockwaves
well see thats really the problem, shockwaves are only about 4" from FULL DROP to FULL LIFT, you will want to drive somewhere between those two limits so that there is actually some suspension in there, otherwise the high spring rate of driving fully lifted will make your ride hell, or the suspension travel of driving with 2" of lift will make you bottom out on ants.
I dont know of any other way to bag a c4 though, or any worthwhile alternatives to shockwaves though, so I am sorry.
Old 02-03-2016, 09:13 PM   #5
52MNResto
52MNResto's Avatar
Re: Shockwaves
if shockwaves only have 4" of travel, why use them? Maybe someone that has them can chime in... I'm thinking about using them on with my 4 link but after reading this my mind is changing...
52MNResto is offline   Reply With Quote
Old 02-03-2016, 09:46 PM   #6
joedoh
joedoh's Avatar
Re: Shockwaves
they have their purpose, on rides that already have plenty of ground clearance but want that super low look when parked. used this way people put bumpstops to actually limit the travel so you dont hit a bump and break the integral shock.
but laying out on the frame, they just dont have enough stroke to get a frame off the ground and still have suspension.
Its some dynamite stuff, but if you want to lay your frame on the ground and raise to drive, you need a setup with more travel. I've never seen a bagged c4 myself.
Old 02-05-2016, 11:47 AM   #7
BIGglaSS
BIGglaSS's Avatar
Re: Shockwaves
Well, technically not in a C4, but close enough. It can be done. My next C4 truck will be bags.
Not mine:
Rear end: http://67-72chevytrucks.com/vboard/s...306237&page=21
Front end: http://67-72chevytrucks.com/vboard/s...306237&page=25
BIGglaSS is offline   Reply With Quote
Old 02-03-2016, 09:28 PM   #8
Advanced Design
Advanced Design's Avatar
Re: Shockwaves
Here is some information from Ridetech on Shockwaves and the longest stroke is 6.9 inches. Don't know if those are applicable for IRS. The ones recommended for front only have a 4 inch stroke like joedoh pointed out.
While this doesn't help with alternatives AZ Hank, the information might be useful.
http://www.ridetech.com/store/shockw...versal-styles/
Advanced Design is offline   Reply With Quote
