Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-02-2016, 11:15 PM   #1
dinnut
dinnut's Avatar
Front end travel limiters and shock relocation
I changed the front coils on my truck recently to a custom spring from coil spring specialties. It sits a lot lower than it used to. I only have an inch of travel in the front shock before its bottomed out now. Does someone make a relocation bracket that will work with the stock style shock(stud upper mount). I just bought new QA1 single adjustables and don't really want to buy another set of shocks.
And now when I launch the truck I have so much upward travel the alignment is way out of wack when the truck is all the way up in the air. What have yall done for travel limiters on the front end?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 02-03-2016, 08:48 AM   #2
regan wilson
regan wilson's Avatar
Re: Front end travel limiters and shock relocation
If you look at post 198 in my storytime thread my old front end is pictured. Its kinda simple but effective. I used 3/4 all thread with a nut welded to the top of the upper control arm. The all thread will make contact on the crossmember as a stop. You just cut it to length and use a jam nut on top. Its good for limiting around four inches of upward travel. Make sure you buy hardened all thread.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 02-03-2016, 12:47 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I ran into a similar situation many years ago. I fabricated a new upper shock mount bracket and located it at the top of the frame rail. If I would've waited another year, a few aftermarket suppliers started offering them.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-03-2016, 12:54 AM   #4
dinnut
dinnut's Avatar
I decided to order another set of coil springs with another 1.5" of ride height after I realized my control arms are scraping and I can't get it on and off the trailer without dragging badly. Combined with the other two issues I think I'll start with a taller spring
70 longbed
496/th400/Ford 9"
