Old 02-03-2016, 06:23 PM   #1
chiro22
chiro22's Avatar
diesel engine swap advice
Looks like it's time for a new engine in my 1973 Cheyenne. It had a Chevy 350 crate and the cost to rebuild would be comparable to buying a new one.
It got me thinking...and I haven't done much research yet, but if I'm getting a new engine, what about a Diesel? My truck is fairly stock, automatic. I'm sure this is a long complex answer, but just wanted to get a sense of what's possible.
Which Diesel engines would you recommend that aren't too expensive (budget is about 2k) that would be a fairly simple bolt in? would I need to change out my transmission or could I add some type of conversion kit? and what am I absolutely overlooking?
Thanks.
Thank you,
Doc
1973 Cheyenne
"I get up in the morning looking for an adventure."
chiro22 is offline   Reply With Quote
Old 02-03-2016, 07:59 PM   #2
Chevy_mud_truck
Chevy_mud_truck's Avatar
Re: diesel engine swap advice
Probably a 12 valve cummins will be you best and easiest to swap depends on what transmission you have and what type of driving your going to do with it have you checked out the diesel section on here
Chevy_mud_truck is offline   Reply With Quote
Old 02-03-2016, 09:15 PM   #3
chiro22
chiro22's Avatar
This is a weekend warrior, hunting, fishing, camping truck. Some off roading to get out to where I'm camping/hunting and all that.
The Transmission is a stock TH350.
Thank you,
Doc
1973 Cheyenne
Old 02-03-2016, 09:22 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
For $2k you might be able to do it with a 12v Cummins if you can find a cheap donor truck that runs and drives. It can be a bolt in deal but you will have to spend some money to buy mounts and a cross member and there will be some fab/tinkering to go a long with it. But, for $2k, you would probably be in the 6.2/6.5 GM market. That is more of a bolt in and there should be plenty out there being sold off from military bases.
Ryan
1969 Chevy milk truck
Old 02-03-2016, 11:07 PM   #5
chiro22
chiro22's Avatar
That's awesome! What would be the next step up from the 6.2/6.5?
Thank you,
Doc
1973 Cheyenne
Old 02-04-2016, 10:09 PM   #6
Dieselwrencher
Find a money tree. Because the next step up in the GM diesel line is a Duramax. I haven't seen many cheap ones of them lately.
Ryan
Old 02-04-2016, 11:43 PM   #7
Zach079xxx
Zach079xxx's Avatar
Good luck finding a diesel with your budget. If I would've known that I would've done a diesel instead of my 350 build. I would LOVE to have a dmax in my square dang money!
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 02-05-2016, 01:55 PM   #8
dragnframe
With that budget, grab a 6.2 or 6.5. They can be found for cheap out of old RV's and grummans, p30's. obviously regular trucks also. A gm3 Turbo can easily be added and for around $400-500 if it not on there already. Here's a list of stuff you'll need.
1. primary fuel filter added along frame.
2. recommend new fuel lines
3. throttle and kick down cables
4. 2 fresh batteries
5. make a glow plug harness
Most important thing is getting the air out of the fuel lines.
dragnframe is offline   Reply With Quote
Old 02-05-2016, 02:53 PM   #9
chiro22
chiro22's Avatar
Right on!!! Thank you.
Thank you,
Doc
1973 Cheyenne
Old 07-03-2016, 11:12 PM   #10
donthekawguy
donthekawguy's Avatar
I'm picking up a 83 3/4 diesel tomorrow and was just reading up on a build that a diesel magazine did. They recommend getting a 6.2 from a 88 or newer. They say if it has the serpentine drive on it get. the earlier 6.2 are a good motor but cost more to build up.
66 shorty
donthekawguy is offline   Reply With Quote
