02-06-2016, 02:05 AM | #1 |
Found: 12 Bolt rearend (for leaf spring truck)
Edit: Found one! Thanks folks.
02-06-2016, 09:28 AM | #2 |
Re: Wanted: 12 Bolt rearend (for leaf spring truck)
I have several 12 bolts out of blazers may have to move the spring pad width. I would ship through fastenal so someone would need to pick it up at the other end is that doable? If that is possible I can get you some pictures.
02-06-2016, 09:58 PM | #3 |
I'm not sure that's possible but I will send them an email and check.
02-06-2016, 10:02 PM | #4 |
02-06-2016, 10:27 PM | #5 |
I'm under the impression 72's are a different width. Sorry. I can't use them.
02-06-2016, 12:35 PM | #6 | |
02-06-2016, 09:56 PM | #7 |
Unfortunately, I believe 71's are a different width. I'm not interested in modifying housings (with the exception of relocating leaf mounts). Sorry.
02-06-2016, 10:28 PM | #8 |
No problem I can get a measurement if you know what you need
02-21-2016, 03:52 AM | #9 |
Bump.
Still in desperate need of one. |
02-21-2016, 08:35 PM | #10 |
I have one with a flip kit if you are lowering it. 100 for just the bare housing. I also have the rest of this rear-end like the series 4 carrier with 4:10 gears, Kal-tech traction, and new shocks. I wouldn't know where to begin on shipping it.
02-21-2016, 07:40 PM | #11 |
I have a leaf spring rear end already pulled, but I am not sure if it is a '69, or '70 it measures 58 1/4 flange to flange. Do you have measurements? I also have a '67 coil spring rear end next to it for reference, were they the same width? The coil spring housing measures 56 3/4 flange to flange. So its probably from an '70.
'67 C10 shortie. Last edited by HONDAWASAKI; 02-21-2016 at 07:48 PM. |
02-22-2016, 09:01 PM | #12 |
Thanks for the response guys. My diff measures exactly 57" from outside of flange, to outside of flange, or 56.5" from inside of flange to inside of flange.
When measuring from outside of flange: 57" (57inch / 4ft 9inch / 1448mm) When measuring from inside of flange: 56 1/2" (56.5inch / 4ft 8.5inch / 1433mm) |
02-23-2016, 12:00 AM | #13 |
Equal opportunity joke ofender
I think I have one from my 69 GMC I will measure in the morning. Even if correct , not sure how to go about the shipping but can check on that as well
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-23-2016, 02:49 AM | #14 |
I appreciate that. Thanks.
02-26-2016, 09:59 AM | #15 |
Russ
The rear end I have is correct but it has some heavy gouges and pitting in the axle tubes on both sides. I tried several times to get some decent pictures but they are not showing up well in the pics. I did attach the best one .
02-27-2016, 02:59 AM | #16 | |
Thanks Richard. Unfortunately I will have to pass. That doesn't look a whole lot better than the one I already have. Surface rust is fine, but pitting I need to keep away from. I appreciate the effort though. Thank you. |
02-27-2016, 04:04 AM | #17 |
Give this guy a call.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
Tags |
12 bolt, diff, leaf, rearend |
