LS Swap and Air Conditioning Question
I've got a 72K5 that doesn't have air conditioning, so none of the AC components are currently there. Eventually, I will swap in a 5.3 w/AC and was wondering what AC parts I need from the 1972 setup to run AC with the 5.3 engine? I've never tried to setup AC before, so I'm not sure what all I'd need to make it work on a truck that never had it. I don't want to start buying original ACs parts when they may not be necessary. Thanks
#2 | |
Re: LS Swap and Air Conditioning Question
Do you have a pic of that? I didn't say this in my original post, but I'll be changing the dash to an original AC dash so all the original holes and vents will be there. I don't want the AC mounted under the dash or in a place that doesn't "look" original from inside the cab. Behind the dash and under the hood I'm not too worried about the "original" look.
#4 | |||
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Old member
You will need to buy are make the covers to cover the old heater openings though as in the pictures that Wasted Income posted. One for the fan motor and the big panel that hides all the heater openings.
If your truck didn't have AC then a kit would be the easy way. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
Boosted Member
#7 | |
Old member
![]() Quote:
I don't know 100% since I didn't have anything factory, but I believe you can use the factory stuff. The best thing to do would be to contact a vendor that sells the kits (I used LaidBackCreations) and tell them everything you are using/will need so they can put a quote together for you. The basic questions that will get you 90% of the way there will be things like what engine are you using, which accessory drive (truck or car), which controls (factory air or non-factory air, I used the non-factory air), etc.
You can use the original vents. Having a non-ac cab will be good since you won't need the block off plate for the original box, you'll just need to drill the holes for the bulk fittings to go through the firewall.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
![]() Join Date: Apr 2005
If you install a factory a/c dash, Vintage air makes a kit for that. There are separate part numbers for a factory a/c dash or non a/c dash.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Great, it sounds like Vintage Air is the way to go. Thanks
![]() Join Date: Dec 2012
I am about ready to order my kit for a non AC cab. where is the best place to purchase it from? or who is the cheapest?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#14 | |
Laid Back
![]() Join Date: Apr 2010
Best deals around and great service
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#15 |
Boosted Member
Yeah...I guess if he buys one for a chevelle, it probably wouldn't have those covers
