02-10-2016, 09:53 PM | #1 |
Roadtrip!
WIW: NOS 73-87 dash bezel
Not sure exactly what years this was used and it does have a couple of imperfections in pic 2. The aluminum has a bubble in the corner and a spot of some sort up higher. If this is used, it wasn't for long.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-11-2016, 02:00 AM | #2 |
Re: WIW: NOS 73-87 dash bezel
Well believe it or not the "if this is used" comment makes a big difference to some. If the holes look like they have had screws installed than I would say the value is approx 1/3 less at least. With the imperfections I think it's a 200-250 piece if no signs of previous use. The original box definitely helps too.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
02-11-2016, 06:56 PM | #3 | |
Roadtrip!
02-11-2016, 07:19 PM | #4 |
Looks like 84-87. Probably 88-91 suburban too
02-11-2016, 08:05 PM | #5 |
67-72 parts collector,…
Good thread on dash bezel differences:
http://67-72chevytrucks.com/vboard/s...d.php?t=660034 QUOTE: Yes, they can be grouped into 73-74, 75-77, 78-80, 81-83, 84-88. 73-74 bezels have a raised area surrounding the headlight knob hole and a fairly narrow hole for the wiper switch. 75-77 bezels have a larger hole for the headlight knob without the surrounding raised area. And a wider rectangular hole for the wiper switch. 78-80 bezels have some styling / appearance differences but I believe they are otherwise interchangeable with the 75-77 bezels as long as you use the corresponding lower steering column cover piece. 81-83 bezels have more of a squared off shape to the upper corners to match the shape of the dash pad. 84-87 (and 88 R/V series) bezels no longer have a rectangular hole for the wiper switch since it's on the column for these years. And the round hole for the headlight switch is moved up a little bit higher as compared to earlier years. I believe the 89-91 R/V series bezels are very similar to the 84-88 bezels with the only difference being the radio opening.
02-12-2016, 12:19 AM | #6 |
Roadtrip!
Thanks for the info guys.
