02-11-2016, 08:58 PM | #1 |
Ideas for locking hood latch
Has anyone come up with a simple way to lock the hood, or are there parts that I can buy and install?
I have a 1973 Cheyenne k10
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
02-11-2016, 09:50 PM | #2 |
Robert Olson Transport
Re: Ideas for locking hood latch
locking hood pins
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-12-2016, 12:17 AM | #3 |
I'm pretty sure GM started putting the locking hood latches in around 80-81. It shouldn't be too difficult or expensive to tear the latch/cable out of a junkyard truck, and install into yours. I can't recall if 1980 models had the locking hood, hopefully someone can confirm. This would be your best bet as 1980 is similar to your 73.
02-12-2016, 01:15 AM | #4 | |
02-12-2016, 12:30 PM | #5 | |
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
02-12-2016, 12:40 PM | #6 |
I have a late 1980 LWB parts truck sitting in the bush. The early 1980 had round headlights, and late 1980 had square headlights. If I get a chance, will check it out later today. The cable goes through the header panel, than sits on the drivers side fender well. It goes through a hole in the firewall, and attaches to a small release lever.
02-12-2016, 01:31 AM | #7 |
02-12-2016, 01:27 AM | #8 |
I'd kinda like to do that as well. I wonder what it takes to make it work on an older truck.
1973 C20, 350/350 |
02-12-2016, 10:11 AM | #9 |
One of my cars (or my Suburban) came with a universal hood latch with a cable that went inside the vehicle. Somebody must still make one.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-12-2016, 12:10 PM | #10 |
Right on, did more research and I've seen a few cable release ones.
02-12-2016, 12:36 PM | #11 |
Check places like SPEEDWAY.com to see what the hot rod guys use!
02-12-2016, 06:23 PM | #12 |
will do. thanks!
02-14-2016, 11:19 PM | #13 |
Converted my 80 to an interior hood latch release. I sourced the parts from a 78.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
02-15-2016, 06:47 AM | #14 |
Had an 80 Formula Firebird in college. Outside hood release only, no option for inside handle. The previous owner installed an aftermarket one, called a "chapman lock" back then. Here is one I found on a search.
http://www.zlokhoodlock.com/shop-z-l...FdgcgQodwXID_g Looks exactly like the one on the Formula. Worked great. It also kills the starter which helps keep it from being stolen. It was great security in Elizabeth, NJ but may be more than you're looking for.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
02-12-2016, 02:14 PM | #15 |
I am pretty sure the inside hood release latches came out as early as 1977. It was an option so not all trucks had them. If you want to install the factory set up you need the piece the hood latch mounts to that runs the width of the core support, the hood latch(pretty sure the piece that mounts to the hood too) and the cable.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
02-15-2016, 11:07 AM | #16 | |||
Happy to be here
02-15-2016, 12:51 PM | #17 | |
02-12-2016, 03:25 PM | #18 |
I have a 78 Suburban with a inside hood latch.
02-12-2016, 03:43 PM | #19 |
I've had some with and without hood latch inside cab before '80. I had a truck that someone just removed the handle(I think it was a 73) and put alinkage rod and handle from an early caddy or something, and was behind the front licence plate. Not locking but kind of hidden. I think it had a tube grille that your fingers couldn't fit to pop it.
I'm pretty sure the 80 trucks all had round. Just the Silverado and higher trim levels got the squares.
-Cody |
