Old 02-14-2016, 12:51 PM   #1
50dude
victoria secert
ha i needed something to get your attention i know this has been brought up a thousand times and i have done all the searches and im still not sure on a straight answer i have a 50 gmc 1/2 ton and i want to keep original steering box and column im installing a 350 motor what is the best option to fit this in and make everything work i really dont want to offset motor i know its been done help me out thanks
50dude is offline   Reply With Quote
Old 02-14-2016, 01:25 PM   #2
mr48chev
mr48chev's Avatar
Re: victoria secert
Basically you can't get there from here without either offsetting the engine or offsetting the steering box or a bit of both.
I've been trying to figure out a simple cross steer setup that uses a common easy to get box and off the shelf parts for the most part but haven't had time to work on it.
My ongoing truck projects:
Old 02-14-2016, 01:26 PM   #3
pugs
pugs's Avatar
Re: victoria secert
you can with side mounts that bolts to the top side of the frame rails or a tubular that bolts inside the rails or make your own. if keeping it 3spd will need a different bell housing as the the v8 wont bolt up to the stock one and then also a different 3spd trans, drive shaft and rear. stock is an enclosed driveshaft/rear
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-14-2016, 02:43 PM   #4
Coach529
Coach529's Avatar
Re: victoria secert
I offset the motor to the passenger side, and spaced out the steering box slightly.
I used hugger headers which take a bit of room. Ram Horns take up less room and require less movement.
As you can see I opened up the hole in the fire wall for the column slightly.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-14-2016, 04:05 PM   #5
50dude
Re: victoria secert
im using a 4" sid drop axle as it looks like you are to does offsetting box affect the pitman arm thanks for reply and pics
Old 02-14-2016, 04:35 PM   #6
iowaboynca
iowaboynca's Avatar
Re: victoria secert
To be honest, I clicked the title, figuring it was a barn find from Victoria BC...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-14-2016, 05:05 PM   #7
50dude
Re: victoria secert
ha
Old 02-14-2016, 07:32 PM   #8
Coach529
Coach529's Avatar
Re: victoria secert
I just welded the hole closed, redrilled and reamed the hole on the pitman arm so the rod end could be on the inside of the arm.
1949 Chevy 3600
Old 02-15-2016, 12:51 AM   #9
ADchevys
Re: victoria secert
I used ram horns on mine, I think I off set the engine 2 1/4 inches a the steering box 3/4 off an inch. [IMG][/IMG]
ADchevys is offline   Reply With Quote
Old 02-15-2016, 03:38 PM   #10
_Ogre
_Ogre's Avatar
Re: victoria secert
we did a friends 49 a long time ago with the 1'' offset to avoid the steering box/manifold conflict
but... since then i've seen some exhaust manifold that might avoid the offset
while there are different versions, something like this that exit high and to the back
these are 80 c10 manifolds
these might work installed flipped side to side so the outlet was towards the front
the exhaust gases won't know the difference
these are 80 grand prix
shop air compressor timer
Old 02-16-2016, 04:43 AM   #11
tmoble
Re: victoria secert
you know, right that engines are often offset from the factory? nothing wrong with it, just a way to get a little more room.
tmoble is offline   Reply With Quote
Old 02-17-2016, 02:29 AM   #12
Nut Case
Nut Case's Avatar
Re: victoria secert
Anything from VS that is see through works. Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 02-17-2016, 05:36 PM   #13
50dude
Thumbs up Re: victoria secert
thanks for all the responses i appreciate it
