Old 02-16-2016, 06:16 PM   #1
tquiroz
1964 GMC 1000 with a 292ci
I just wanted to share my current build with the community and say thank you to all of those who have helped with their advice directly or indirectly through their threads. I recently picked up this 1964 GMC 1000 with an inline 6 as a daily driver/first truck for my 15 year old son. We are in the process of updating to truck with some mods to make the driving easier and safer on a daily basis. The front has gotten disc brakes and a sway bar from ECP with a hydroboost system to come. The steering has being upgraded to a Unisteer rack and pinion system with new bushing and KYB shocks all around from the guys at Summit. We will be tackling the gearing in the differential soon to make freeway speeds less stressful on the engine. The interior is getting an upgrade in the seatbelt department and the bench seat will be upholstered in a field tan waxed cotton fabric. Due to the truck being used to haul stuff, we are considering using Rumber, an extruded recycled tire board product, for the bed.
Here are a few pictures of the build so far:
The first night when we picked up the truck.
https://www.instagram.com/p/BAYqMUbMjNy/
The following day.
http://www.instagram.com/p/BAnL0JSsjKA/
Brakes and shocks.
http://www.instagram.com/p/BB27AC4MjI_/
Brakes and undercarriage.
http://www.instagram.com/p/BB27ZBdsjJy/
Rack and pinion.
http://www.instagram.com/p/BB271sYsjKk/
tquiroz is offline   Reply With Quote
Old 02-16-2016, 11:35 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 1964 GMC 1000 with a 292ci
Really cool! Could I see some pictures of the inline 6?
Old 02-17-2016, 04:03 PM   #3
tquiroz
Here are some more picture links of the motor and other stuff:
Motor - Inline 6
https://www.instagram.com/p/BB5dJDNMjDP/
Other side of the motor
https://www.instagram.com/p/BB5fN2asjHB/
Front end
https://www.instagram.com/p/BB5eL3WMjE5/
Rear of the cab
https://www.instagram.com/p/BB5e4qVsjGV/
Dash
https://www.instagram.com/p/BB5ekGdsjFs/
Rumber Sample
https://www.instagram.com/p/BB5V9TusjEs/
Old 02-17-2016, 04:05 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Thanks! Not to spoil your bubble or anything, but that engine is actually either a 230 or 250.
Old 02-18-2016, 02:27 PM   #5
Crazy Rusty
Crazy Rusty's Avatar
How are you able to tell? My engine looks exactly the same and doesn't match the I6 website 292 pictures but the casting number (3851659) on my block says 292.
edit... Ah the fuel pump is in a different spot.
Crazy Rusty is offline   Reply With Quote
Old 02-18-2016, 02:35 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
The fuel pump is located right next to the dizzy, the smaller 4 inch side covers and the location of the dipstick tube.
According to the Inliner's Power Manual your casting number is a 63-66 292. But several times I have seen the same casting numbers on different blocks. For example, Casting number 3854036 is on a 66-70 230, and a 62-79 250. So not to uncommon to see that. Unless your fuel pump is in the middle of the engine and the side covers are 6 inches tall you don't have a 292. Another way to tell is the higher block deck height from the water pump on the 292 vs smaller engines and the bypass hose on the 292 that isn't on the smaller engines.
Old 02-18-2016, 02:39 PM   #7
62jimmy
Two things I look at to identify the 292 are the taller side covers of the 292 and the location of the fuel pump in relation to the motor mount, behind versus in front. I'm sure there are other ways, but these are quick. EDIT: I see TJ responded with a more complete answer
62jimmy is offline   Reply With Quote
Old 02-18-2016, 04:36 AM   #8
padresag
http://6066gmcguy.com/Inline6.html
explains about the I6 engines
ron
padresag is offline   Reply With Quote
