Old 02-17-2016, 12:14 AM   #1
SuperCtruck
SuperCtruck's Avatar
Modify 283 air cleaner base HELP!!
Building a sleeper high hp 350 to look like a factory bone stock 283 in my 1964.
Since I haven't purchased a air cleaner yet
I'm Thinking of pulling the trigger on a original 1964 283 2 barrel air cleaner (eBay) and fab a carburetor hole that will fit my 5"1/8" quadrajet. Any suggestions on which base maybe able to work or has someone pulled this fab off?
1949 Chevrolet 5 window
1970 C10 CST swb, fleet side
1964 C10 swb, bbw
1968 Camaro coupe
1968 camaro convertible (cream puff)
1972 K10 swb 4wd SuperCheyenne
SuperCtruck is offline   Reply With Quote
Old 02-17-2016, 01:59 AM   #2
Bad4wd
Re: Modify 283 air cleaner base HELP!!
I machine a adapter out of brass to go from 5 1/8" to 4" + for the early 4 barrel air cleaners on top of my edelbrock. Or you can cut an weld.
Bad4wd is offline   Reply With Quote
Old 02-17-2016, 02:59 AM   #3
NVS-C10
NVS-C10's Avatar
No need to buy a 2-barrel one.. the 283/327 repops have 4 3/8" opening for factory 4-barrel carbs. You can do adapter from there.
NVS-C10 is offline   Reply With Quote
Old 02-17-2016, 09:52 AM   #4
SuperCtruck
nice!! I'm No machinist but I can weld and that's what I have in mind so far.
Aweseome... You sells these adapters? I'll give summit a call
1964 C10 swb, bbw
1968 Camaro coupe
Old 02-17-2016, 09:59 AM   #5
SuperCtruck
Found a adaptor and risers that look like they'll work even though they're plastic?! thanks Fellas
http://www.spectreperformance.com/ca...dapters-risers
1964 C10 swb, bbw
1968 Camaro coupe
Old 02-17-2016, 11:49 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Those adapter assume you have a smaller carb throat and are using a larger air cleaner base.
What if you want to do the opposite? Use a newer carb (5-1/8" carb throat) and want to use an older air cleaner. I don't think those adapters will work.
Old 02-17-2016, 04:39 PM   #7
SuperCtruck
You're exactly right, they won't work. Maybe have to go plan B and weld. thanks
1964 C10 swb, bbw
1968 Camaro coupe
Old 02-17-2016, 05:55 PM   #8
The Rocknrod
Moderator
Well if you do, can I put in a order for one?
Old 02-17-2016, 06:48 PM   #9
ray_mcavoy
Here is an option if you want to buy one pre-made:
Air cleaner assembly with 5" base
They also sell just the base if you already have a lid:
5" base with 1" vent
And they also offer bases with various size carb openings with & without the vent tubes.
Here is the complete listing --> http://www.dr409.com/02_Engine_Ext_1.html (scroll down to the "Air Cleaners, Small Block Reproduction" and "Air Cleaner Parts" sections)
ray_mcavoy is offline   Reply With Quote
Old 02-26-2016, 10:54 AM   #10
SuperCtruck
Thanks for the advice Ray__mcavoy, just received my base.
1964 C10 swb, bbw
1968 Camaro coupe
Old 02-26-2016, 10:55 AM   #11
SuperCtruck
Bottom mount
1964 C10 swb, bbw
1968 Camaro coupe
Old 08-14-2023, 08:32 PM   #12
jrusher
Im just swapping a 327 into my 283 truck with a 4bl quadrajet and trying to do same thing keep it looking like a factory 283 . What base plate did you use and did it work with a quadrajet carb ? Thx
Bottom mount
jrusher is offline   Reply With Quote
Old 02-17-2016, 09:07 PM   #13
The Rocknrod
Moderator
Would that 5" base fit a Edelbrock Carb?
Old 02-17-2016, 09:18 PM   #14
ray_mcavoy
Show Cars says on their site that the 5" air cleaners are for use with "aftermarket AFB" carburetors ... which is basically what the Edelbrock carbs are.
I believe they're simply rounding off the measurement to 5" even though the Edelbrock & Q-Jet carbs are actually 5-1/8". Similarly, they list the air cleaners that fit the stock Rochester 4gc carbs as 4" even though those are actually something like 4-7/32".
Old 02-17-2016, 10:50 PM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
Another solution might be to simply use a base from a filter that fits, and drop the early air cleaner lid over the top and tighten it down.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-18-2016, 12:52 AM   #16
SuperCtruck
AWESOME
Good stuff I'll do some looking, thanks
I may just buy a cheap mr gasket 14" and see if the base will work, thanks
1964 C10 swb, bbw
1968 Camaro coupe
Old 08-15-2023, 08:40 AM   #17
sirJim
This is basically what I did, 2 barrel original on a i think 10" cheap china aircleaner bottom and a K&n filter sloped out to the original. A little shaping the bottom half and works great on a quadrajet
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 08-15-2023, 09:28 AM   #18
Chevy Fleetside
Chevy Fleetside's Avatar
Pretty much what I did. Had the cheap open filter base and put my stock base over it and was happy it worked. This thread is pretty old so I am sure they solved their problem already.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-14-2023, 10:33 PM   #19
cwcarpenter98
cwcarpenter98's Avatar
If you have some welding skills, just cut the center out of the 2 barrel base, bend up some sheet metal to the height and diameter you need, then weld it up. That's what we did with mine when I went to a Quadrajet. I did have to make it tall enough to clear the HEI dizzy
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-14-2023, 10:46 PM   #20
jrusher
Ya was hoping not to have to cut my 2 bl base up but might have to if i cant find a 4bl base that will work
Old 08-14-2023, 11:11 PM   #21
cwcarpenter98
Looks like the link Ray posted a couple years ago is no longer active, but I did find this from I believe the same place. Maybe this could work for you? https://show-cars.com/product/1952
They also have a lot of other air cleaner stuff available: https://show-cars.com/02-engine-external
Christian Carpenter
