Old 02-17-2016, 01:11 AM   #1
chiro22
chiro22's Avatar
rust cover up
got a 1973 Cheyenne shortbed as a hunting truck and the bed has come rust spots, as well as the front quarter panel and few little spots here and there.
Before I drop the cash for a rhino lining or something like that, are there any recommendations on which rust cover up spray (ie rustoleum, etc) works best for bed and for the body?
Thank you,
Doc
1973 Cheyenne
"I get up in the morning looking for an adventure."
chiro22 is offline   Reply With Quote
Old 02-17-2016, 12:29 PM   #2
Matt Man
Matt Man's Avatar
Re: rust cover up
Is it rot or just surface rust? If there is major pitting or rust through I would get the areas repaired before it gets any worse. I have had good luck with rustoleum paints.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-17-2016, 01:30 PM   #3
chiro22
chiro22's Avatar
Re: rust cover up
Most of it is surface rust...there's a few bits of rot...was thinking of doing a little filler/small fiber patch on those.
thoughts?
Thank you,
Doc
1973 Cheyenne
Old 02-17-2016, 01:44 PM   #4
Matt Man
Matt Man's Avatar
Re: rust cover up
Got a picture? The only proper way to do it is to cut it out and replace with new metal.
Old 02-17-2016, 02:24 PM   #5
chiro22
chiro22's Avatar
Re: rust cover up
I'll take a few photos at lunch
Thank you,
Doc
1973 Cheyenne
Old 02-17-2016, 09:38 PM   #6
midnight rambler
midnight rambler's Avatar
Re: rust cover up
If its surface rust por 15 work good if you follow the directions. Ifs it cancer cut it out.
midnight rambler is offline   Reply With Quote
Old 02-17-2016, 09:46 PM   #7
Jrgunn5150
Re: rust cover up
If you're talking tiny surface rust spots, hit em with a wire wheel and some ospho, or spring for a pint can of POR 15 or Chassis Saver.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 02-17-2016, 11:07 PM   #8
1redbowtie3
1redbowtie3's Avatar
Re: rust cover up
http://www.nationaltoolwarehouse.com...YwFhoCg_Pw_wcB
I've been using this for small rust
spots, after POR15 ...
1985 K20 4spd
1978 K20 4spd
1redbowtie3 is offline   Reply With Quote
Old 02-17-2016, 11:10 PM   #9
Jrgunn5150
Re: rust cover up
Nice find! The stuff I use is way more than that!
J.R.
Old 02-18-2016, 02:33 PM   #10
chiro22
chiro22's Avatar
Re: rust cover up
Here are some photos of the rust...the first photo are the rust marks in the bed, the 2nd and 3rd, show the rust in the line down the middle, that's just went leaves and dirt on either side and the last is obviously more rotted.
I have a buddy who does really nice rust work, before I can get to him and drop a load of cash, are there any rattle can solutions to treat and will help with the surface rust? And any way to treat and fill the rot for the time being?
Thank you,
Doc
1973 Cheyenne
Old 02-18-2016, 02:38 PM   #11
midnight rambler
Re: rust cover up
I would cut it out, looks like its deeper than surface rust
Old 02-18-2016, 04:07 PM   #12
Matt Man
Matt Man's Avatar
Re: rust cover up
I don't think covering it up for now will help much, especially the top of the bed rail. For the bed just sand it down the best you can and spray some rust inhibitor on it to help slow it down. Best solution is to get your buddy to fix it properly. You have a 73 cheyenne short bed 4x4 this is a truck worth fixing properly. Good luck!
Old 02-18-2016, 07:22 PM   #13
chiro22
chiro22's Avatar
Re: rust cover up
I hear yeah. It def deserves the full treatment. Thanks
Thank you,
Doc
1973 Cheyenne
