Old 02-17-2016, 02:25 PM   #1
XGreen
Fitting a Dana 80?
I have heard of a few guys putting Dana 80s in there C10s but I have never really seen some good pictures of the fit. Does anyone have details on this? What size u-bolts are used and are modifications needed to the trailing arms?
I have a 68' C10 Suburban and a dually Dana 80 I want to put in it.
XGreen is offline   Reply With Quote
Old 02-17-2016, 09:57 PM   #2
kwmech
Re: Fitting a Dana 80?
Why a massive 80. I just put in a D70HD in a chassis I'm working on. That thing is pretty damn beef. An 80 is even more so
kwmech is online now   Reply With Quote
Old 02-18-2016, 10:26 AM   #3
XGreen
kwmech, I totally agree. It is huge but I have it. It will defiantly be a challenge but I think that's why we do this stuff. I think it will be pretty cool but it my just be my delusion, haha.
Is the D70HD a 4" axle tube? What size U-bolts did you use?
Thanks for the response by the way.
Old 02-18-2016, 12:55 PM   #4
kwmech
I had to have the u-bolts made for the leaf spring pack I am using
Old 02-18-2016, 01:05 PM   #5
XGreen
Oh, Ok. I am talking about a trailing arm set up
Old 02-18-2016, 09:03 PM   #6
cleszkie
cleszkie's Avatar
If you want beef, why not a 14 Bolt? They are a dime a dozen, cheap, lighter than a D80, have a lot of aftermarket support (gearing), and much easier to adapt to our trucks. I put one in the rear of my Blazer. Doesn't seem like the installation of the D80 will be worth the effort. But hey, its your project! Just be sure to post up pictures!
cleszkie is offline   Reply With Quote
Old 02-19-2016, 09:51 AM   #7
j_cst_10
j_cst_10's Avatar
One thing to consider is the added unsprung weight of the Dana 80. Typically wouldn't be an issue with a leaf spring truck but those light duty coils might need to be beefed up to keep the rear end in control.
j_cst_10 is offline   Reply With Quote
Old 02-19-2016, 10:12 AM   #8
XGreen
Thanks for that piece of advice. I was wondering about that and it is nice to hear someone else bring that up. My plan is to get heavy duty drop springs and use No Limits shock relocation kit with $$$ nice new shocks.
Does that sound like the right idea? All suggestions and advice helps. I appreciate it.
Old 02-19-2016, 10:32 AM   #9
j_cst_10
j_cst_10's Avatar
I am definitely no expert in that field but I think you may have an issue only because you are probably adding at least an extra 150 lbs if not more (much larger drums, 4 rims and tires, that heavy drum hub assembly that slides over the axle tubes, etc).
Buy the heaviest duty crap you can stuff under there and see what happens. I have a leaf spring rear 72 C20 and I though about putting a narrowed dually set up under it at some point so this is kind of cool with the burb.
Old 02-19-2016, 12:30 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Are you planning on narrowing the differential or adding step fenders?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-19-2016, 01:06 PM   #11
XGreen
I am going to add dually fenders. Measuring, I will need at least 6" fenders. My plan is to get this all driving by Julyish so it is not going to be pretty. After its driving and reliable I may make the body pretty. But for now my story is "RatRod".
Old 02-22-2016, 12:51 PM   #12
XGreen
Does anyone know what the wall thickness of the Dana 80 axle tube is?
Old 02-22-2016, 04:22 PM   #13
cleszkie
cleszkie's Avatar
Your local law enforcement may not look favorably on the open wheel concept with the outer tires protruding completely beyond the fenders. You may have to fab up the dually fenders sooner than you think. Just something to consider.
Old 02-22-2016, 09:21 PM   #14
kehstr
kehstr's Avatar
agreed 100%
kehstr is offline   Reply With Quote
Old 02-22-2016, 09:27 PM   #15
kehstr
kehstr's Avatar
Dana 80 tubes are 3 5/8 inches in diameter and 9/16 inch thick
Old 02-23-2016, 09:44 AM   #16
XGreen
Thank you. That is exactly that I was wondering.
Old 02-23-2016, 09:43 AM   #17
XGreen
Yes, of course. Good point. I will not be driving it without fenders. I think I need marker lights as well.
Old 05-10-2016, 10:21 AM   #18
Alex V.
Alex V.'s Avatar
You do realize a D80 is way overkill for that C10, right? Sure, it'll look cool, but it seems like a lot of effort to have an axle that the rest of the chassis can't possibly match in load capability. I could see a 14 bolt, but even so the HD 1/2 ton axle in these years was a D60 if I'm not mistaken. That's what I have in my '67 C10 and it's been overhauled once in 330,000 miles of towing, hauling, long tripping, etc. Dad's '86 K20 has a semi-float 14 bolt that's seen the GVW exceeded more times than I could count over its 361,000 miles and AFAIK it's never been apart. I like full-floating axles as much as the next guy (have a FF 14 bolt in my '85 C3500) but based on the vehicles I've spent years with/around with semi-floating axles there's really no need unless they're being used in such capacity as would warrant a heavy duty 3/4 ton or 1-ton running gear.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-10-2016, 10:46 AM   #19
XGreen
I'm not going to disagree with anything you said. I know how dumb this my be but it is a fun experiment I am trying. I have a 68' C10 Suburban and a 96' RAM 3500. trying to make them into one. If it turns out to be a flop I will just have to do something different. But in the mean time I will keep chugging along with this. I got beefy springs , good shocks, beefing up the frame a fair amount with some boxing and x-bracing and the front end will match.
What I am looking for is anyone's advice/help on how to make it work.
Old 05-10-2016, 10:52 AM   #20
Alex V.
Alex V.'s Avatar
In spite of the impracticality, I get it. Have you sized up the Ram chassis and weighed the merits of just putting it under the 'Burb body with a big honkin' 502 or 8.1/4L80 combo, or something along those lines?
Alex V.
Old 05-10-2016, 11:01 AM   #21
XGreen
I thought of that. the frame of the RAM is quite a bit wider and the wheel base is much longer so I would have to do significant frame mods either way. I just figured this way might be the rout to go. It will save me some body mods and I really wanted the training arm rear suspension. the whole drive line (Cummins 12v & 6-speed) of the RAM is going in the C10 too as well as the front cross member (disc brakes, power steering, IFS, 8-Lug).
Old 05-10-2016, 11:01 AM   #22
drfloyd
+1. I was about to suggest the same thing.
drfloyd is offline   Reply With Quote
Old 05-10-2016, 01:50 PM   #23
Alex V.
Alex V.'s Avatar
Sound logic, I'm sure. On a 2WD I'd want trailing arm suspension, too. I assume this means an 8-lug conversion, too? Wish I was closer so I could snap up your wheels.
Alex V.
Old 05-10-2016, 10:42 PM   #24
XGreen
That is an affirmative on the 8-lugs. Front and back.
Old 05-11-2016, 01:38 PM   #25
Cali72K20
Cali72K20's Avatar
These are on a local CL listing, never seen these style helper springs before or if they will help your build.
Good luck on your project!
http://santamaria.craigslist.org/pts/5560322142.html
Casey
Cali72K20 is offline   Reply With Quote
