02-17-2016, 11:44 PM | #1 |
Wilwood ebrake
Has anyone installed the Wilwood ebrake system? I have the lines ran and rear hooked up but I'm a little confused on where to tie in the front of the cables. They seem way too long to me. Am I suppose to cut them done and hook them up to the equalizer bracket for the old ebrake?
02-18-2016, 12:48 AM | #2 |
It's Better With Nitro
Re: Wilwood ebrake
Are you referring to the disc style e-brake like the ones I run, or the drum/shoe style that fits inside the rotor hub?
For mine, I use a Lokar e-brake intermediate cable kit to connect to the balance bar near the transmission tail.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
02-18-2016, 01:19 AM | #3 |
Re: Wilwood ebrake
I'm using the drum/she style the fits inside the rotor hat of the Wilwood disc brakes. I have the cables ran up to the tail of the transmission to all the existing ebrake mounting points but the cables are way longer then they should be. So I'm curious if I'm over looking somethings but the Wilwood instructions don't mention trimming the provided cables to proper length. I want to make sure I'm not missing something before I trim them
02-18-2016, 11:33 AM | #4 |
Re: Wilwood ebrake
You're not missing anything...they make the cables long to accommodate extra long applications. I had to trim mine a little.
02-18-2016, 11:55 AM | #5 |
Re: Wilwood ebrake
02-18-2016, 01:20 PM | #6 |
Re: Wilwood ebrake
I don't and my truck is at the paint shop. It's very similar to the factory set up, except I fabricated a bracket to locate the e-brake balance bar assembly below the tubular transmission crossmember since I raised the drive train a little in the chassis. Here's an old photo of the balance bar:
